Question about Kenmore 24 in. 16593 Stainless Steel Built-in Dishwasher
Kenmore wont run
I have an kenmore elite dishwasher model 16599201 it just fills up and does nothing the lights on the front timer just flash it will drain when cancel is pushed the float is working as it does fill up
  • 3 more comments
  • gordmiller40 Apr 13, 2009
    yes the pan is full and float is working
    yes i have i can hear the float click when i press on it and when water is removed it will fill back up to same level
  • ERIC BAKER May 11, 2010
    After pressing cancel and draining do'es it fill back up with water without restarting?
    The float is sometime's referred to as a flood switch, have you tried removing some of the water from the inside of the dishwasher then restarting?
    When it fill's up with water is the float switch all the way up?
reg501
  • 413 Answers
SOURCE: Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Posted on Jun 07, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Model 655-15974990 won't wash or drain
What DOES it do? Just fill with water? Or doesn't it even do that? Do you have any lights on or flashing? Do you hear any noises when you try to run it?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore 17602 dishwasher. It is filling, but then
timer needs replacing.I am not sure of that model but if its the dial model thats the problem...the clock type timer fails at that setting...try a lighter or heavier selection on the dial.
Jul 20, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Kenmore Elite Dishwasher(665.15979990) wont drain
If the control panel is still lighting up I think it the thermal fuse has blown if you can take out the control panel and in that you will find the fuse you can test this with ohm test and here is a pic of what the fuse looks like and if you do replace this make sure you replace the new wires that come with the new fuse good luck hope this helps
Nov 21, 2009 | Dishwashers
Feb 22, 2009 | Kenmore Dishwashers
Kenmore Elite dishwasher Options light up but nothing runs.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher wont fill up but can hear the motor....
dishwasher? could be the fill valve bad. or the float switch is stuck in the up position.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite
the time is flashing 42 on my kenmore elite front loader but when u presss the buttons noting happens
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 16593 Stainless Steel Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
