Anyone know where we can find the Manuals and Schematic for a Acoustic 850 - 8 Channel P.A. head with double VU Meters - ? Musicparts has info for an earlier model - Analog Rules - Any help would be greatly appreciated. L.
  • 73 Answers
This is as close as I could get. http://www.musicparts.com/products.asp?Company=Acoustic
The 860 is probably very close match.
Paul
Posted on Jun 13, 2009
I will buy a Technics se a900s amplifier, but
I think you are saying you want to connect the amp and use it's vu meters but not connect it to speakers?
Presumably you are already well catered for in the matter of amplification but lacking good vu meters?
There is a fair amount of information about this premium amp online including operating and service manuals that can provide a better answer than I can.
One note of caution; it is generally bad practice to operate a power amplifier without a load at the output and it might damage the amplifier. If it is desired to operate it without speakers providing the load, dummy loads are available.
I suggest you have a look through ebay or Amazon where you might find digital or analogue vu meters at a reasonable cost or alternatively I believe computer software could turn your laptop into vu meters.
May 11, 2016 | Technics Audio Players & Recorders
What are the specifications for audiobahn a2200hcx amplifier
The specs are as follows:
RMS Power Rating:
200 watts x 2 chan. @ 4 ohms
400 watts x 2 chan. @ 2 ohms
800 watts x 2 chan. @ 1 ohm
• Bridged:
400 watts x 1 chan. @ 4 ohms
800 watts x 1 chan. @ 2 ohms
1600 watts x 1 chan. @ 1 ohm
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meters Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable High-Pass Crossover: 50-750Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.05%
Channel Separation: 50dB
Apr 15, 2011 | Car Audio & Video
HI. I've got 2 DECA 724 with one channel blown on each. I will like to fix this amps they have work great for me hate to change this amps.
The DECA amps are nice... As I recall the transistors are not easy to find but they do exist or substitutes are available. I am trying to find a schematic... I have found one that one has to purchase from Musicparts...
Jan 17, 2011 | Music
Yamaha tdm 850
http://www.tdm-trx.nl/Manuals/4TX_97_Suppl.Manual10.pdf
as near as i can find hope it helps
Jan 24, 2010 | 1999 Yamaha TDM 850
Need the radio code
well, I don't know, the dealer has all of that info, but if your lucky you can pull the old radio and maybe a previous owner or mechanic was thoughtful enough to write the code on top. Locate the two springloaded tabs on the left and right sides of the face, push them in gently with a knife or flat screwdriver and use them to pull the radio out. Good luck.
Jun 01, 2009 | 1995 Volvo 850
Replacement parts for Pyle power amp PT-2000
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Apr 15, 2009 | Pyle PT-2000 Amplifier
When i record my vocals its only in one channel why!
It seems that the recording input source is provided as "Line In" whereas you need to select the "Mic In".
This is because the "Line In" is a stereo input and expects input for both right and left channels whereas the "Mic In" input is a mono input which is the same as our default condensed mic device is.
By the way, you would be able to see the graphic VU meters while recording, weren't they displayed that the recording is done only for one channel ?
Always use VU meters for checking the levels for recording, they are available with almost all recording softwares.
Hope this helps.
Thanks
Mar 31, 2009 | Sony Acid Music Studio 7 Full Version for...
HELLO I HAVE 670ZX WITH OLD STYLE VU METERS. EVERYTHING WORKS GREAT EXCEPT THE VU METERS ARE SLOWING TO A STOP ALMOST. THERE IS OUTPUT ON BOTH CHANNELS AND IT SOUNDS GREAT BUT...........METERS ARE FAILING.
hi, a vu meters is a coil with a magnetic field, if it is slowing to stop, probably the coil is to old and you have to calibrate it (specialist) the best for you: replace the vu meter.
Apr 22, 2008 | Audio Players & Recorders
Can't get power from amp
Please quote make and model of amp.
Nov 03, 2007 | Car Audio & Video
128 people viewed this question
 Grubhead
Grubhead
