Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My freezer is leaking inside the freezer area. I took off the panel on the inside and can see that it is leaking by the top of the coils. The water then freezes at the bottom of the freezer. Again all this is happening on the inside of the freezer( where the food is)
    Problem Solver:
  • 11 Answers
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Posted on Apr 18, 2009
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer will not freez
maybe you have leak capillary tube! and now lack of freon! find the leak with using of wet rub in soap! you see bubbles at the leak area! then resolder the affected area, then re charge a freon.
Oct 03, 2007 | Frigidaire FRS3R5EMB Side by Side...
I'm getting water coming from the vents inside the refrigerator TR18MW. How do I dis assemble the area between the freezer and refrigerator compartment?
Today, after removing the freezer and fresh food compartment doors. I removed the back panel in the freezer. I then took a rubber mallet and started to bang the inside front edge of the plastic freezer floor until I could reach my hand at the back of the freezer floor and wiggle it forward. Once I removed the freezer floor I removed the ice that built up behind the foam panel. I then cleared the drain hole at the back which was caked with Ice and other garbage. I put it all back together and now it is fine.
Jan 23, 2010 | Amana Refrigerators
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Top freezer leaks water into lower fridge on our sears kenmore #70267990
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 26, 2009 | Kenmore Refrigerators
Water comes out freezer door
Defrost that drain with a hair dryer and remove the debris . That should solve the problem . The red you see ( this is normal ) , is the defrost heater , thawing out the frost on the coils . The defrost water HAS to go out the drain or it will freeze the opening and the defrost water will flow out thru the bottom of the freezer door .
Aug 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool Side by Side making loud humming noise from freezer side
I had the exact same issue last night. I would press on the back panel long enough and the noise would go away only to return this morning at 4am. I finally got up took all of the bins and shelves out and found an very large accummulation of ice at the bottom (floor) and walls of the freezer. The ice accummulation was causing the rattling of the tubes in the wall of the freezer (I don't know what you call them), but they were frozen over on one side. I found this out once I took the back wall panel off of the inside of the freezer. I also found the drain hole back there and it was frozen over solid, as well as my ice dispensing unit at the top of the freezer. This whole problem began when I turned on the ice maker 3 days ago. I used my hair dryer and hot water to clear all of the ice from both areas and now it is nice and quiet. Don't know if the acccummulation is due to some defrost switch gone haywire, but at least the rattling is gone and my freezer is back to square 1 for the time being and I saved myself a visit from the appliance guy in the meantime. Took me a total of 1 1/2 hours to do it all.
Aug 07, 2009 | Frigidaire FRS26R4A Side by Side...
I have a frigidaire FRS26ZPH side by side that leaks water about twice a day on the floor by the doors. Where are the drains located so I can see if they are blocked?
What is happening is that there is a drain at the back and bottom of the inside of the freezer area and that drain is clogged with ice (freezer set too cold?) from inside the freezer or dust (you do actually vacuume out those coils once a year right?) from the back of the frigidaire. To fix this issue...
(Total work time about 30 minutes. 60 minutes counting explaining what you are doing to your friend or significant other :)
1.  Unplug the frigidaire so you don't zap yourself.
2. take everything out of the freezer, remove the shelfs and un screw the maintenance access panel at the back of the freezer area.
3. You should see a drain area at the bottom of the coils, using a straw or something semi-flexible, snake out that drain from inside the freezer to see if the clog releases. If there is a lot of ice and you cannot even get to the clog, be patient and gently remove the ice - DO NOT DAMAGE the coils!
4. Remove the back access panel to the frigidaire. Viewed from the back, you are looking for the fat black hose coming from above and behind the right side the fan (this is why you unplugged remember?) into the drain tray under the fan. Gently lift up on the hose so it flexes up and toward you so you can snake the hose from this other end too.
*Hint: If you are REALLY nice to your friend or signifigant other, they will gladly pour another dixi cup of water in the drain from inside the freezer so you can see for yourself that the drain is now clear.
5. Now the drain is clear and all your ice cream is melting in your sink. Be sure to reposition that black hose back to where it was in the drain tray so it does not get chopped up by that fan at a later date. Next... reverse your removal of the back maintenance access panel on back of the frigidaire. Re-install the maintenance access panel on the inside of the freezer area. (Now is a good time to use a clean & warm washcloth to gently clean the inside of your freezer.) Reinstall all the shelfs. Place your ice cream and all other items back into the freezer.
*If you have an ice maker, be sure to dump all that half melted ice now - it will just refreeze into an iceberg later and break your ice machine so no cubes come out.
6. Plug the frigidaire back in. Tomorrow, check the bottom of the freezer for another sheet of ice accumulation, meaning something else is leaking inside of your freezer. (Could be your ice maker)
Jun 20, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Whirlpool ET22DK NOT Cooling
Hi, Is the compressor running at all? Are the fans running? Whe you took the rear panel off in the freezer, was there any frost on it at all?
Vic
May 17, 2009 | Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
203 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
