Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Carburator problem,18 H.P Vangard V-Twin(350777-1113-E1)
The carburator on my 18 H.P Vangard V-Twin(350777-1113-E1) is spewing fuel. There is a port on the left side below the fuel intake. This seems to be a direct access to the float bowl. Upon running the fuel is streaming out of this port(just started all of a sudden). When I put my finger over the port to stop the gas flow the engine starts sputtering. I do not recall any hose or other type of connection, exploded parts view from the Briggs and Stratton web site does not show this side or any greater detail. Any suggestions
  • Bob Mel May 05, 2012
    My engine just started doing the same thing last night. Identicle engine and code!
    YELP!!! Cannot figure out wha this leaking hole is!
    Bob
    Scholar:
  • 152 Answers
It sounds like the needle valve is stuck open. This is connected to the float, and when the bowl gets low the float pulls this needle out of its seat and allows fuel to run in. Sometimes tapping on the bowl can resolve this. The needle is usually made of brass and can become corroded from water or from sitting or wintering over. if you take the bowl off you could also clean this up if tapping a little does not resolve the issue.
Posted on Apr 13, 2009
OH MY!
I have the same exact problem that started yesterday on the same motor and code!
Does anybody know what is causing this?
Bob
Posted on May 05, 2012
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Vangard v twin valve adjustment
I can walk you through it but too long for here so...Go into Utube and ask the very same question..STARTING WITH UTUBE THEN YOUR QUESTION..some very good sites there..good luck
Aug 21, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have rebuilt the carburetor on a 16HP Briggs and Stratton Vagaurd. But can not get gas to engine, it runs when I pour gas in the carburator, What could be the issue.
Have you checked to make sure the float level is set correctly, or that the float isn't sticking, not allowing fuel in?
Are you pouring fuel into the top of the carby, or syphoning it in via the fuel inlet?
Jan 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Will start with choke up and will run for about one minute
Sounds like the filter may be plugged up..not expensive change it see if that helps..good luck..
Dec 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Vangard model 305447 type 0068 e1 code 05102611 will not say runining on rough ground
It can be several problems. It might be that the carburator is loose and when it shakes over rough ground it is sucking air and stalling. If it is something else you might try rubber mounts under the engine to take the vibrations out of it. Also check for loose wires.... there may be a wire grounding out when you travel over rough ground. look for loose connections or frayed wires that might touch metal and cause a ground
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor won't run unless choke is on. It is a 16 hp v twin.
check breather to make sure it is clean and clean the carburator
Apr 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Sep 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
1,959 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
