Question about Whirlpool LER4634J Electric Dryer
Dryer worked for two days
Then quit working. No response when i hit start button and timer isn't working either. When i went back to look at it the outflow metal tube shocked me. Unplugged, looked at wires from wall outlet and into dryer. All seeemd fine except red wire at back of dryer just looks old. Not sure if I blew a fuse in the Dryer or what? Any help?
  • afe70 May 02, 2009
    Dryer stopped working. We checked it out and cannot find the problem. When we push the button on the door, the timer clicks but when we close the door and push the start button nothing happens. What could it be?
  • 351 Answers
Yes, you did. I advise you to either call me here Whirlpool Parts Surplus OR get a new pigtale for the dryer. AND a thermal fuse. Take the 9-11 1/4" screws out you will see a white skinny fuse straight down off the outgoing air duct. check continuity or connect the wires. I advise you to get a new cord before you start it again.
Best of luck
Mark
Posted on Apr 19, 2009
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
Whirlpool LER5636PQ1 DRYER starts when I hold the button then shuts off
Your motor has gone bad. Think of the motor as a starter in a car. When you turn the key (press the start button) power is applied to the starter, to be specific, the stator also called the start winding, same as the dryer. Then the rotor takes over and the stator drops off. With your machine the rotor isn't engaging and the stator is taking the load and shutting down.
May 27, 2012 | Whirlpool Dryers
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
The dryer was working and the electricity went off and came back on while I was outside. I thought it was done, took out the lothes and put in new wet clothes, turned the timer knob and hit the button. It...
Try resetting the dual breakers for the dryer in the house electrical panel--push off, then on. Power surges from the utility can cause the breakers to trip. If this doesn't help, then you probably have a problem within the dryer. Good luck!
Feb 06, 2010 | Dryers
Dryer just quit
I would check to see if you have 220v to back of dryer where the cord mounts to dryer Check the door switch, , Take back off dryer There is a fuse in the back its white oblong 2 wires coming from it, left side on blower outlet ..be carefull hook the 2 wires togather and if it comes on the fuse is bad needs replacing same way with the door switch.
Aug 29, 2007 | Dryers
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
