Question about Fuji FinePix S3000 Digital Camera
Fuji FinePix 3800
I cannot get my LCD to function as far as seeing the object I want to shoot.Everything else like the setup functions fine
    Genius:
  • 2,985 Answers
This is probably a CCD failure Contact customer support as CCD failures can be a known thing where cameras are replaced free. if not then a new camera is the next move A repair is not likely to be an economical thing
Posted on Sep 17, 2007
SOURCE:
Fuji S6000fd; black display, both lcd and viewfinder
I have the same problem except everything is white, not black.
Jul 05, 2009 | Fuji FinePix S6000fd Digital Camera
Internal memory full - how do I find it? Ann
If you do not have a memory card inserted, the camera defaults to the internal memory, both in shooting and playback modes. You can transfer from internal to a card using the "copy" function from the playback menu. The internal memory can be erased from the playback menu using the format function in the "setup" menu. Don't erase (format) until you are sure the images are stored safely elsewhere.
Jul 02, 2009 | Fuji FinePix S1000FD Digital Camera
How to initialize a fuji card 12mb .
Go to ;the "setup" menu and find the "format" option. Using the format function should prepare the card for use and get rid of the error.
Apr 05, 2009 | Fuji FinePix A340 Digital Camera
My Fuji Finepix S2000hd has lost all LCD fuctionality
My S1000fd has a EVF/LCD button. It is used to switch from Screen to veiwfinder. Is it possible you pressed it by mistake when the camera was turned on ?
Feb 19, 2009 | Fuji FinePix S2000hd Digital Camera
Preview option does not work.
u cant see it in lcd do u see anything on lcd is it totally blank then its a lcd failure but if it shows signs and functions then it might be a big problem coming ur way that is CCD failure , pls check ur pics by connecting are they normal without any white or pink shades then replace lcd screen
Feb 16, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Need a driver for a Fuji FinePix 3800 digital camera for Windows Vista
I solved this problem by letting windows install a driver for me. it works fine so far. I have used it as a web cam. I have not downloaded pictures yet though.
Sep 08, 2008 | Fuji FinePix 3800 Digital Camera
Fuji FinePix 3800
Not sure if it is a solution, but there is a class action pending in New Jersey District Court for the defective power problems experienced by owners of the Finepix 3800. It seeks reimbursement for the cost of repair or replacement.
Jun 08, 2008 | Fuji FinePix 3800 Digital Camera
Fuji FinePix Z3 camera broken display
Best and cheapest solution is to buy a faulty Z3 on Ebay with an intact outer glass and do a swop. You'll need a tri-blade screwdriver, a very small 4-bladed( posi-drive), and care, but steady hands and a 'follow your nose' plan should see you through. There is a Z3 on Ebay presently to do the job. You can practice on that before you attempt your own. Good luck.
Feb 04, 2008 | Fuji FinePix Z3 Digital Camera
Blank photos
This is a CCD sensor problem ( see enclosed image of one taken out of a Cannon camera with similar specs to yours ). Contact Fuji agent as this is repaired under warranty .48f4e65.jpg
Feb 02, 2008 | Fuji FinePix S5000 Digital Camera
LCD screen and Viewfinder not functioning
there is probably a problem with the connection between the sensor and the displays, I would send it back to Fuji for repairs, because it would be almost certain death for your camera for someone who does not have the machinary and clean room to service the camera to try to fix it
Nov 22, 2007 | Fuji FinePix S9500 Zoom Digital Camera
Fuji FinePix S3000 Digital Camera Logo
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
