Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I need to instal a mechanical time switch
I just buy a T104 ,Intermatic mechanical time switch, to control the energy in my water heater.... I need instruccione how to conect the wires in & out... Can anybody help me?..... Thanks a lot...
JOHN
  • 50 Answers
John, i'm assuming the water heater is 240 volts and the timer is 240 volts, if ok follow these instructions. the 2 wires coming from the breaker box goes on 1 & 3 screws, also each yellow wire going to the timer motor goes on 1 & 3. now the 2 wires going to the water heater goes on 2 & 4. be sure to ground the timer box
Posted on Apr 13, 2009
Intermatic T104 timer manual switch stuck
To remove timer from enclosure, there is thumb spring located top inside box. Push up on spring, hold onto timer dial, tip outward and lift upward.
Disconnect power before removing mechanism.
Override lever should snap back and forth crisply, and turn pump ON-OFF.
If override lever is not turning pump ON-OFF, then check that you have 240Volts across terminals 1 and 3. Check that timer dial is rotating and keeping good time.
Then move override lever to ON position and check if you have 240Volt across terminals 2 and 4. These terminals are Hot when pump is supposed to be ON.
Reset circuit breaker, may be tripped off on one leg, listen for crackling sound of loose breaker, use nose to smell for burning, tighten wires on breaker, move wires to another same-size circuit breaker.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
If timer is not functioning, then buy clock motor and trippers.
OR. You can buy the T104M mechanism-only, and snap into existing enclosure.
OR. It may be cheaper: Buy the whole T104 and snap out of new enclosure and install mechanism into existing enclosure.
Jul 19, 2012 | Intermatic T104 24h 208-277v Mechanical...
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Pool pump starts randomly (as if there is a short) even when it is not set to start and stop. Otherwise works fine, not sure if I need to replace unit or dissassemble and clean or ????? T21004R
Sounds like 240Volt WG1573 clock motor has gone bad and needs replacement. But more checking is needed.
You posted under T2100-4R which is 60 amp Intermatic control panel with a single T104M 240Volt timer mechanism.
All Intermatic timer mechanisms can fit into same control center, so you can possibly have different timer mechanism inserted into the T2100-4R control center.
The control center can have up to 4 circuit breakers.
Instruction manual shows that timer can also have fireman's switch that is wired to pool heater and causes pool heater to turn off 20 minutes before pool pump turns off.
http://www.poolandspacontrols.com/products/mechanical%20controls/60%20amp%20pool%20and%20spa%20control%20panels.aspx
(1) First thing: If you have T104 mechanism, do a troubleshoot run-down to see if trippers, clock motor, or wiring are suspect:
(2) Next would be to check the circuit breakers for loose wires, burned connections, or the smell of burning or crackling sound that says breaker is loose on the busbar.
(3) Check for loose wiring on T104 and test circuit:
(a) Push the manual override lever to OFF position and test across terminals 1 and 2 and then across terminals 3 and 4 to make sure timer is turning off power to pump. Both tests should show 0 volts.
(b) Push manual override lever to to ON position and repeat test above. Both tests should show 240 volts.
If the test fails, then buy new T104M timer mechanism.
(4) If the T104 timer is turning off both lines in the 240Volt circuit, then pump cannot turn on since neither wire is Hot.
However if your T104 timer is actually a T101 timer or if timer has different wiring, where timer is turning off only 1 leg and not both legs of 240Volt circuit, then pump has one hot wire available and a short to ground could cause pump to turn on unexpectedly.
Jul 08, 2011 | Intermatic T21004R- Pool-Spa Mechanical...
Hi expert: I am installing intermatic P1353me digital pool or spa mechanism and having trouble to figure out how to do this heater Firemen Switch connection. My existing pool timer is T104 and there were...
1) Fireman's switch automatically turns off heater few minutes before turning off pump.
Not all pool timers have fireman's switch.
If old timer did not have it, then don't worry about it.
P1353 has wires marked for fireman's switch, so simply don't use them if you don't want to.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
page 21 of manual shows wiring for fireman's switch.
2) T104 and P1353 comparison
Difference 1: T104 turns OFF both hot wires, while P1353 turns Off 1 hot wire.
http://waterheatertimer.org/Compare-120-and-240.html
Difference 2: T104 controls 1 240V load with 1 time schedule, while P1353 controls 3 different 240V loads, each with different time schedule.
Check that wire(s) coming from breaker can handle all 3 loads.
http://waterheatertimer.org/Color-codewire.html
3) 240Volt T104 is wired as follows:
http://waterheatertimer.org/images/T-104-240-Volt-400.jpg
Hot1 from breaker connects to T104 terminal 1
Hot2 from breaker connects to T104 terminal 3
There is constant power on terminals 1 and 3, each terminal has 120V when combined makes the 240V circuit.
Load1 wire connects to T104 terminal 2
Load2 wire connects to T104 terminal 4
Terminals 2 and 4 have power whenever timer turns ON
4) Definition:
In electric wiring, Line means power from breaker, and Load means wire going to light,fan, motor, pump.
5) Converting T104 to P1353
http://waterheatertimer.org/images/P1353-timer-350.jpg
http://waterheatertimer.org/images/P1353-terminals-566.jpg
Hot1 from breaker connects to P1353 terminal 1
Hot2 from breaker connects to P1353 terminal 2
This will power timer electronics and timer clock and switches.
Jumper wire is placed from Hot1 at terminal 1 to each Line terminals 3 5 and 7.
This will put power at the switch, and when switch turns ON, then power will flow from Line wires to Load wires and then on to the Load.
Load 1 connects to terminal 4, Load 2 connects to terminal 6, Load 3 connects to terminal 8
To complete each 240V circuit, Hot2 is connected directly to each Load.
6) You say 'salt' system connects to terminals 1 and 3 on T104, then those wires are carrying constant 240V to that device. So Salt system connects to terminals 1 and 2 on P1353
7) Get a second opinion:
I frequently contact Intermatic for various problems.
P1353 is fairly new product, and manual is long, and I might not fully understand your problem or wiring.
Intermatic answers their email.
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Intermatic Digital 3-Circuit Timer...
I have an Intermatic T104 timer switch for my water heater that will not shut off power to the water heater even when manually switched ''off''. Looking at the back of the switch, it seems like there is...
It sounds like the switch lever linkage has come loose. You might be able to investigate this without removing the timer -- but make sure water heater breaker is off.
If you can't get good access to the linkage, the timer will have to be disconnected and the "innards" removed from the box.
It's probably just a loose or missing screw.
Charlie
Aug 31, 2009 | Intermatic T104-20 Indoor Hot Water Timer
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
164 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
