Question about Kitchen Ranges
Need replacement oven racks size 17 1/4 x 24 inches.
We need replacement oven racks for a Sunray Stove...the size is 17 1/4 x 24 inches.
watugot
  • 290 Answers
SOURCE: Kenmore Electric Stove - Gourmet Edition
Thanks for the numbers.
The 628 in the model# tells us it was built by Frigidaire. The date code in the serial number is less clear because it is a different code than their current serial number designations that have been in use since the mid '80's. The style of the stove makes me think late '70's, I would guess '77 or '78 from the first 3 digits of the serial number.
The thermostat should be easy to check. If the broil function in the large oven works, the thermostat should be ok. It is a simple switch that should read closed across the contacts when you turn it to any temp setting when the oven is cool.
The power for the oven will also go through the selector switch which routes the power to different components depending on the setting.
The power also goes through switches in the clock that allow the timed bake and self clean functions to work.
If there is no wiring diagram in the stove, you will probably need one to diagnose the problem if the thermostat checks ok. I would suggest getting one while it is still available in case you need it in the future.
Once you have found out exactly which part you need, you should be able to use the Frigidaire part number from the parts list on the Sears site to track down a replacement part through a local appliance parts dealer. You may have to take the part to them to try to visually match up a replacement. Thermostats and selector switches are usually pretty generic in their operation between manufacturers, the problem lies in finding one that will mount to your control panel properly and that your knob will fit so that you can keep the same uniform look along your control panel.
Please post back with what you find out or if you have any questions.
Thanks/Mike
Posted on Mar 04, 2008
  • 1073 Answers
SOURCE: We live in an apartment
what is the model number
Posted on Apr 23, 2008
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
  • 81 Answers
SOURCE: nedd a top oven element for brown stove 24"
since you're online, do an online search for the company and inquire about a replacement element for your model.
Posted on May 07, 2009
frederiquema
  • 76 Answers
SOURCE: I need a oven rack that is 18.5 inches wide and 16
Go see in places like Salvation Army, Trift store, Garage sales. Try putting an add in the paper and online.
Posted on Oct 26, 2009
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
I need an oven rack with the measurements of 22 3/4 inches by 16 1/4 inches. How do I find one at a reasonable price and asap?
You can find the rack
Oven Rack - Size: 16 1/2 x 22 3/4 inch.
Part Number: AP2124960
made by FRIGIDAIRE
Our Price: $35.39
Compare at: $42.11
You Save: $6.72
To the following link http://www.appliancepartspros.com/Appliance-Parts/?keyword=oven+rack As you can see you can find many other racks in the same link.
Nov 26, 2010 | Sears 61301 Gas Kitchen Range
GE XL44 Gas Stove & Oven: When using self cleaning oven can I put the stove cooking racks inside to clean also?,
Is this my wife asking this ? lol, i had the same arguement with her, dont leave the racks in, it will tarnish them possibly bend them,that stove gets up to 900 F
Oct 29, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    F2 error code ?
    This is a common oven temperature sensor code.
    It must be replaced.
    Unplug the range.
    Open the oven remove the racks.
    The temp sensor is in the top right or left rear of the oven. About 3 inches long silver in color and about the size of a thin pencil. Remove the screws,remove the sensor and unplug it.
    Replace it with a new sensor and you will be fine.
    Dec 12, 2009 | GE JBP66 Electric Kitchen Range
    I need some replacement parts for my Waterford-Stanley Trinity wood stove. The Left and right top baffles. Do you know where I can buy them.
    LOOK AROUND THE STOVE FOR A BRACKET WITH THE MANUFACTUOR DETAILS AND CONTACT THEM FOR INFORMATION ON PART OR GO TO A SRAP YARD AND YOU MIGHT GET LUCKY .
    Nov 29, 2009 | Ovens
    Racks falling down
    I have the same problem with a Kenmore oven. Looks like the oven walls have bent outward.
    Oct 13, 2008 | Kenmore 75503 Stainless Steel Dual Fuel...
    Kitchen Ranges Logo
    658 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
