Question about Fisher and Paykel GWL11 Top Load Washer
Water leak I have noticed a water leak on the floor under my washer had a service man in who claims it is the water pump leaking also states do not have repair part(pump) has anyone else had this problem. If so what may be cause and I live in Marietta Georgia if pump is needed where can I obtain one Thanks for your help
  • 6 more comments
  • Blamey May 03, 2008
    I also have a F&P GWL11 My washer is 2 to 3 years old and it leaks out the bottom and on to the floor. It's enough water that it runs across the garage floor.  The strange thing is that it  occurs intermittently and I really can't pinpoint a pattern or cause.  Can I fix this? Where can I get a repair manual
  • Anonymous Oct 26, 2008
    water leaking eco-smart but only with certain settings--can't pinpoint where its coming from on the bottom
  • Anonymous Nov 13, 2008
    I have a 4 yr old GWL11 and noticed water on the floor.
    Did some checking under the washer and found out it was coming from the pump drain under the washer. This has a motor and a fan. It cost me 75.58 and I ordered in Fisher and paykel Appliances, inc.
    949-790-8900
    part no: 420325P
  • firewalker91 Nov 28, 2008
    I have a fisher Paykel gw11 that also has leak under the front right area on floor with each wash.
    could it be the pump? if so where can i get parts to do it myself? looks pretty simple.
    thanks
    Hey, I am just about 10 mins north of Marietta, let me know if you can get the part.
    Also, it seems my washer has had a smell of sour water like it hasnt emptied completly before. Could this be a sign of pump problems as well?
  • artsupest Nov 28, 2008
    I have the same issue. A very small amount of water leaks under the washer, Fisher Paykel GWL 11. I need very specific help like, 1. first pull out the machine, 2. etc.....to find problem and repair it. s
  • rpalmer77 Dec 01, 2008
    I have the same model that I bought about 2 1/2 years ago. Water doesn't leak out from under it every load, which makes it harder to pinpoint the problem. The washer has also stopped spin drying the clothes. I'm sick of this product.
  • loriegarcia Dec 05, 2008
    I have the same problem with GWL11 model. The water is leaking from the bottom of the washer. I called our local Fisher Paykel Appliance Service and was told it will cost us approx $130 or more to come out and replace the drain pump, plus the parts. Where can I find the drain pump for this model? My husband can fix just about anything. Is it hard to to replace?
We replaced our pump motor about a year ago it cost about $65.00 Couldnt find a repair center in Portland Or. area, did it ourselves. Fairly easy. We ordered the part from the appliance center where we purchased about 10years earlier
Posted on Sep 14, 2007
  • 240 Answers
Can you send me the model number of the unit. We own a washer and dryer service business in Marietta as well, we may be able to get our hands on a place that can get them for you. Let me know and I will see what I can find, at least a number to call. In fact, try this link out: http://www.expertappliance.com/fisher&paykel-washer.html They may have it what your looking for. If not, let me know. Thanks!!!!! Jim
Posted on Sep 13, 2007
SOURCE:
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
Water leak
Ford ****** a real mans motor unlike them overated gas guzzlers in america ,water leak which is difficult to answer without all the facts ,now its going to be a diesel thats for sure but you havent stated the age or mileage but as these things can cover 50,000 miles in a year on comercial use then it wouldnt surprise me if the seal on the water pump but without my head under the bonnet to look i couldnt tell you but if you see water on the floor at the front of the engine then this would indicate a water pump but just offhand with a look i honestly couldnt tell you
Jan 10, 2012 | Cooling System for Ford Transit Connect
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 24, 2008 | GE WJSR1070A Top Load Washer
Top Load Maytag Neptune Washer
hello i am a appliance repair man. do you was a lot of sandy cloths? what is happened is your seals are bad on the washer. i bet the sales men told you when you bought it that you could fill it plum full. its not true. i have seen this machine in and out of my shop so many times its not funny. by the way if you do fix it please put a surge protector on your machine. trust me it will save you more headaches. if you have any more questions feel free to email me at [email protected] next time you buy an appliance call a repair man and ask them what kind of problems that the appliance has first.
Nov 08, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
380 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
