Question about Braun 360° Complete 8985 Electric Shaver
Braun 360 Cleaning base
After a complete cycle of cleaning, the cleaning liquid reamins in the base, it does not drain back into the container. How can I fix this?
  • Anonymous Dec 06, 2008
    where do i buy the cleaning liquid
  • Anonymous Mar 31, 2014
    The activator goes through cleaning cycle but solution cleaner doesn't empty
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
Posted on Oct 28, 2007
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at See link below
Oct 09, 2010 | Braun 8585 Electric Shaver
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
Sep 07, 2010 | Braun 360° Complete 8985 Electric Shaver
I replaced the cleaning liqud cartridge but it shows the red light indicating it is empty.
here is the solution..follow the steps please..
Thanks in advance for rating me..Regards
  • Replace the cartridge in the base station and close it.
  • The indicator light should cycle then change to green. If it doesn't then unplug the base station, wait a few seconds, then plug it back in.
  • Press the lock button to clean the shaver. If everything went well it should start cleaning like normal.
    Aug 27, 2010 | Braun 360° Complete Electric Shaver
    Unable to charge the shaver. The charging unit is plugged in, but it doesn't seem to be able to charge the shaver.
    The cleaning base is the problem. It probably got wet inside and the circuitry is damaged. This is almost always why these go bad. You dont have to replace it to use your shaver as you now know that you can charge the shaver directly from the cord.
    If you want the convenience of the cleaning station, you will need to replace it. You can find a new one at See link below
    Feb 16, 2010 | Braun 360° Complete 8985 Electric Shaver
    8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
    the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
    Just don't beat it against anything hard.
    Oct 29, 2009 | Braun 360° Complete 8985 Electric Shaver
    Cleaning base thinks it's empty
    I had the same problem. Try taking out the cartridge and in the compartment where the razor sits in to get clean, there is a drain hole on the left side. Try cleaning the hole out with a toothpick or something similar. It seems that the drain hole clogs and causes this problem. I just did it and all seems to be working fine.
    Feb 10, 2009 | Braun 360° Complete 8985 Electric Shaver
    Base floods with solution during cleaning cycle
    OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
    Nov 04, 2007 | Braun Flex XP II 5790 Electric Shaver
    Braun 360° Complete 8985 Electric Shaver Logo
    475 people viewed this question
    Top Braun Health & Beauty Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
