Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
My Whirlpool/side by side needs a PUR water filter change. Would that cause my ice maker to stop working? I have water in the water dispenser, just no ice in the ice maker. There does seem to be ice formed, just not ejected into the basket. I have unplugged the unit in the hopes of resetting it. I have double checked the ice bin is in place. Any other ideas on things I might try? Thanks
  • imjustvisiti Apr 14, 2009
    Unable to locate my owners manual, how do I get the PUR filter out of the grate area under the freezer area?
  • 490 Answers
The filter will cause your problem
Posted on Apr 13, 2009
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Apr 30, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Side by side Whirlpool fridge with ice maker as well as ice and water dispenser in door. Dispenser works for both ice and water so water is getting to the system, but the ice maker has suddenly stopped...
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Mar 24, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Feb 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Refrigerators Logo
191 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
