Question about Sharp Televison & Video
Is there ANYONE in this organizations who can give me instructions on how to set a Sharp VCR to automatically come on and go off? So far I have received NO INFORATION ON MY QUESTION. SHARP VCR MODEL NO. VC-H952U
  • 371 Answers
Direct from the Sharp Website here:
Gota question? It’s probably been asked before. We’ve got answers to yourmost Frequently Asked Questions right here. Questions about productoperation, features, troubleshooting and more. Check here first andhelp yourself.
Is there ANYONE in this organizations who can give - bullet_red.gif When using the “Timer” feature on my VCR, the unit does not come on at the specified time.
Wesuggest checking the date and time in your menu. You may also consultyour operation manual under “Setting the Clock”. After the informationfor the program to be recorded is input, make sure that the power tothe VCR is shut off.
Posted on Apr 13, 2009
I need instruction to set recording for sharp h952 vcr
You need remote to get menu to set the clock then go to timed recording setting. Then you load a new tape, then shut down the vcr and wait for the timer to start the vcr and recording for you.
If you need a manual, google for sharp vcr manual download free from sharp website.
Aug 26, 2010 | Sharp VC-H952U VHS VCR
Sharp organizer
you organizer should have cam with a cradle to set it on. that will connect to your computer either serial2 or usb. did yours not come with one of these?
Aug 15, 2008 | Sharp ZQ-590
Why can't I find the codes for DirectTV remote?
The DirectTV remote should have the option to
scan for the code check the instructions for
the automatic scan method most likely you
turn on the tv, dvd/vcr keep pressing button
until channel changes or set turns off which
ever button you use if you dont have the
instructions try this address
http://www.satex.com/directv/remote_codes.html
Nov 22, 2007 | Polaroid FLM-3232 Television
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Setting the correct dateon a sharp organizer yo 530
first of all you shoud find the time and date setting on sharp pw then set it if it not work same problem again then open carefully your sharppw and find the cell battries and replace it
Mar 29, 2010 | Sharp PW-E350 Electronic Dictionary
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Dec 25, 2007 | Sharp Wizard OZ-730
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Tamper Proof Button and resetting it and the the code
if memory serves me correctly there is a re-set button on the back of the vcr by the co-axial connectors or on the bottom of the vcr. hope this helps
Feb 07, 2007 | Sharp VC-H992U VCR
Televison & Video Logo
176 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
