Question about Motorola Radio Communications
Older MOTOROLA HT 600 HAS STATIC PROBLEMS NO
OLDER!!! MOTOROLA HT 600 HAS STATIC PROBLEMS NO MATTER WHERE YOU ARE OR WHAT BATTERY YOU USE. I WOULD LIKE TO FIND SCAMATIC FOR IT SO I CAN TRY THINGS ON MY OWN.
Solder connections broke inside of radio you will have to take apart an re solder check with magnifying glass
Posted on Apr 26, 2009
When I use my motorola talkabout t5710 all I get is a static surronded voice which is so broken up you can't understand a word. What can I do about it?
Very likely the battery. But first, try these things: make certain the mic hole s not clogged, it is tiny. Clean the battery contacts on the radio AND the battery. Get them shiny! Try again. If static persists, try another battery or buy a new one. There is no easy repair.
Jul 30, 2016 | Motorola Radio Communications
To much static
Static can be a sign of a bad or poorly charged battery. Try trading batteries with a known good unit and see if the problem is solved. If so, replace the battery. Other issues which might cause static are a bad speaker or other internal issues.
Jan 29, 2014 | Motorola VL50 Two Way Radio
One of my radios keeps emitting a constant static, whil the other work perfectly. Help?
Contant static can be a sign of a bad battery. Try trading the battery pack between the units to see if the problem moves to the other radio. If so, you need to replace your battery pack. Any other problem related to static would not be able to be resolved, as the T4500 is non-repairable.
Best regards.
Dec 15, 2010 | Motorola Talkabout T4500 (7 Channels)...
When i try to talk on another motorola spirit mu21cv it makes a cracking/static sound and it transmits what im saying but i have to have it very loud for it to work and even then it makes a very loud...
Two things come to mind. First, you may have a bad battery. It is typical for a bad battery to cause the radio to have static, or poor transmit. Second, you may not have the radios set to the same frequency as one another, or one is on a narrowband frequency, and the other is wideband. (Depending on the age of the two units.)
Try switching the batteries between a working radio and the staticy radio. See if the problem moves to the other radio. If so, replace your batteries.
Check your programming, if you don't know how, contact your local Motorola dealer or give us a call (google our name). We can walk you through programming over the phone.
Lastly, if all these suggestions fail, your radio may be in need of repair. Flat rate repair is currently around $69 ea.
Best regards.
Oct 18, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
I have took all the leads off from coil to plugs and forgot the set up on suzuki gsx600f Hreg
If you are sitting on the bike the left coil has an orange/white wire on the top and a white wire on the bottom.The HT leads go to plugs 1 4.The right coil has an orange/white lead on the top and a black/yellow wire on the bottom.The other HT leads go to 2 3.It doesnt matter which HT lead goes to either plug as thboth HT leads on the same coil fire at the same time (wasted spark system).Hope this has helped or you have already sorted it out.
May 14, 2010 | 2008 Suzuki GSX-R 600
Excessive static
Constant static is a sign of either a bad/low battery or a defective radio. Sorry. You might try switching the batteries from a known good radio to this one to see if the problem is solved. Clean your battery contacts with a pencil eraser to assure good connection. If changing the battery does not solve the problem, the radio is defective and will need retired.
Best regards.
Apr 07, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Need a user manual for ht 1000
For this concern that you're looking for the user manual for this device , you can go to this link then download the user manual save a copy of the manual to your computer or print it out for future use.
http://www.repeater-builder.com/motorola/jedi/ht1000-specs.pdf
Jan 06, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Remote code SAMSUNG
I have a samsung HT-AS720S surround system it is 21 months old. the right speaker has popping and static coming from it, had to disconnect it. Moved wire to another speaker-same thing. Contacted samsung tech to help, went through a number of test they said I have to send it in for repair. Warranty is only one year.
I also have a problem with the sound when watching tv it goes from normal to very quit, it's irritating-no matter how high I turn it up the base goes up but volume stays down. On shows that are on DVR all sound is good. Watching a DVD is also good.
Please help
Nov 05, 2008 | Audio Players & Recorders
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Problems setting up Motorolla GM300
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Jun 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Radio Communications Logo
122 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
