Question about Panasonic PT-51G44 51" Rear Projection Television
Verticle I just got this projection TV. Now the picture goes from regular size to oversize and then back. Could ti be the verticle hold? How can I fix it?
  • 8 more comments
  • bigtimo1964 Sep 12, 2007
    How do you reset to factory settings? Are we talking about all of the setting on the screen or the color settings?
  • Anonymous Nov 10, 2007
    about every 3 to 5 minuts my projection TV goes from regular size to oversize and then back. How can I fix it?
  • Anonymous Nov 11, 2007
    my panasonic rear projection 51 inch TV goes from regular size to oversize to wide screen and then sometime it is the right size. What could it be? How can I fix it?
  • Richard DeJarnette Nov 11, 2007
  • Richard DeJarnette Nov 17, 2007
    Comment:
    Best Solution:
    Please reset to factory settings, if problem still there check the v-sync IC.
    all the best, kindly rate this solution.
    Need to know:
    How do you reset to factory settings????
    Pease some let me in on how to.
  • Flipping Nov 30, 2007
    This TV zooms the picture when a bright scene is on the screen. When there's a picture that is dark, the reception is normal. When there is something bright on the screen, it's as though someone is pushing a zoom button & the picture expands sending the top & bottom portions off the screen.
    Sometimes when a mixed picture that is a little bright appears on the screen, then the TV just jumps as though the horizontal or vertical hold is faulty. This TV is about 15 years old. Do they still have horizontal & vertical holds for these TV's?
  • nicholasbloc Dec 18, 2008
    I have the same problem too so i cleaned it out got all the dust out and then it worked fine for about a week and now its doing the same exact problems as listed above no one has any idea what is causing this???
  • rwbrown234 Dec 30, 2008
    My projection tv zooms in and out with the brightness of the picture. The picture is dark most of the time.
I have The same Problem...Big Screen Projection 51 inch Panasonic PT- 51G44 Zooms in and out constantly. I would love to have a solution.
Posted on Apr 12, 2008
    Problem Solver:
  • 18 Answers
Please reset to factory settings, if problem still there check the v-sync IC. all the best, kindly rate this solution.
Posted on Sep 12, 2007
After tv has been on for a while the picture goes in and out of multi colored verticle bars with horizontal rolling.
Thats problem have lost of harizontal sync.Try to adjust the horizontal hold until the picture back to normal.
Jul 05, 2011 | Televison & Video
My mitsubishi projection tv comes on and works fine for a few minutes then lines like a verticle hold in different colors mostly green flicker up and down the screen like a verticle hold, I would like to...
Mine has the same problem. This kind of TV does not have a color wheel. I changed the 4 1000 uF caps on the DM board like advised here, but it did not fix the problem, but it did change it, so I suspect it's a similar problem somewhere on the signal or main board. The caps were getting ready to burst.
Sep 23, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Picture is off center. Bottom edge is about
sounds like VERTICLE problems...check verticle circuit for bad Capacitor...bad cap might be visible...you must locate verticle ckt inside of TV and change BAD cap!!!
May 19, 2010 | Samsung HLN4365W 43" Rear Projection...
Tv screen
very common problem you have a verticle problem either you have filters that are leaking or your verticle ic is going bad in the shop depending what size this unit is and weither it is a tube set ot a lcd or plama or led
May 14, 2010 | Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Picture up side down
change the verticle cables on the deflection coil on the tube.
note just the verticle cables ( verticle has only two cables)
what is happening is that current is reversed.
get it to some body a tech.
my tv gave me a similar problem.
Feb 08, 2009 | Bush 2871NTX 28" TV
Logik lt2974 small picture
the problem is in the verticle section, if you are a technician check a verticle IC and a capacitor of that stage. to allocate a verticle stage follow 4 cables coming down from deflection coils, two of these wires goes near transformer, this is horizotal and the other two goes near an IC this is verticle. positive idea.
Nov 22, 2008 | Zenith B25A02Z TV
The picture rolls vertically sometimes.
I would check the capacitors in the verticle deflection circuit. Also try resoldering the verticle output as well as the verticle yoke pins where they connect to the chassis. Mitsubishi has had some trouble with their capacitors, you may have one that is leaking. Let me know if I can help you further.
Jan 13, 2008 | Mitsubishi VS-60801 60" Rear Projection...
Trouble!!
Most of the time when theres no picture on a mitsubishi projection set, theres no verticle sweep. Most likly cause is the verticle output IC or the b+ feeding the IC or Both. This is not a consermer replaceable parts. It could also be the PIP module if the set has one . Remember these sets have alot of hi-voltage even when the sets unplugged. Good Luck
Jun 22, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Panasonic PT-51G44 51" Rear Projection Television Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
