Question about Sewing Machines
Dont know how to adjust the settings
Kenmore 158.16600 didnt come with manual.How old is it.
  • 374 Answers
Hi there, follow this set up of thread as shown on figuresdont know how to adjust the settings - 3054202.jpgthe set up of bobbins thread wind should be counter clokwise as shown on figures.
654a65c.jpg set adjustment for dial tension should be #3 to #4 and stitch set up
to #12 depend on fabric this set for cotton,polyester.
then set up all this and .have a nice sewing.you can also view swing on www.youtube.com on search box type sewing machine.
don't forget to rate me. thank;s
Posted on Apr 14, 2009
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
Hello
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Hello! I need to replace the motor on a Kenmore Series 16 machine. Model 158.162. The Sears website states the motor 5168, is not available anymore and no substitute is recommended by the manufacturer. ...
I realy dont think that you will find a new motor for a old kenmore, you may be able to find one on craigslist/ebay. How do you know it is the motor? Could just need new brushes or a new foot control. I have never had a bad motor on a old kenmore. replaced brushes and many foot cotrols.
Not that it could not happen but it would be rare.
hope this helps
Mar 25, 2011 | Kenmore Sewing Machines
Inherited old kenmore 10 sewing machine. it is clean and have no problem threading etc. but believe tension and settings are off because back of stiching is pulled and "loopy" what are the correct...
It sounds like your upper tension is too loose. A good place to start adjusting is at the number three on your tension dial, but you need to pay attention to how the stitches look rather than what the number on the dial is. I wrote a Tip on Adjusting Tension. Take a look at that and see if it helps.
Robbie
Aug 01, 2010 | Kenmore 744-08BH Mechanical Sewing Machine
Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Jan 24, 2010 | Sewing Machines
Old sewing machine, no owners manual
I got the same machine when I was 12 years old and still use it today. Try adjusting the tension - it's the know with number 0-9. To decrease tension turn it to the left. To increase tension turn it to the right.
On the side of the bobbin case is a screw that also can be turned with a small screw driver to increase or decrease tension the same way as mentioned above.
If you send an email to me at rhonda_1961@yahoo.com I can see about getting a copy of the manual to you. It doesn't have the cover but everything else is there.
Aug 18, 2009 | Brother LS-2125 Mechanical Sewing Machine
Thread goes off screw when i start sewing
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Kenmore Owners Manual
Jul 03, 2009 | Kenmore 15358
Bobbin on 12102 kenmore
Welcome to FixYa!
Don't mess with the bobbin! They rarely need adjustment. Sloppy bottom stitches usually come from two things. Tension too loose on the tension dial or improper threading.
Dial tension should be set on about the mid range and you must, must, must, make sure that you have the machine in the proper thread patch. Have someone check it with you. Sometimes a fresh set of eyes will help you spot an area that you missed.
Thanks and if you found my solution helpful, please reward me with a FixYa rating.
Sep 26, 2008 | Kenmore 12102
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
160 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
