Question about GE WBSR3140DW Top Load Washer
How do I take out the agitator?
How do I remove the agitator since a belt is stuck underneath.?
  • slliddicoat Apr 14, 2009
    What are the steps to take off the agitator ?
I believe for that model, to remove the agitator you must reach inside with both hands and firmly grasp the lower part of the agitator and pull straight up. It may be a little difficult but should come off. Make sure you get it all the way back down when putting it back on. Hope this helps.
Posted on Apr 23, 2009
  • 234 Answers
SOURCE: How do I take out the agitator?
I'm not sure if this is the same as your machine but here is a link to a possible solution:
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
I hope that this solves your problem.
Posted on Apr 15, 2009
  • 240 Answers
SOURCE: kenmore 80 series leaking....plastic tub cracked on the bottom
if you removed the large nut (round with four notches cut in it ) then tub should be free. sometimes these "rust together" on the hub. wd40 and a hammer to knock it free. try rocking the basket to break free. you did remove the tub ring(white plastic part on top), right?
Posted on Apr 28, 2009
  • 181 Answers
SOURCE: I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
Posted on May 14, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: clothing stuck under agitator
The agitator pops off. You will need to use a flat head screw driver or something short enough to get in the tub and under the agitator and it will pop off. They are on there pretty good so it will take some work
Posted on Jun 01, 2009
SOURCE: Need to remove agitator as material jammed underneath
remove agitator as material iammed
Posted on Apr 14, 2010
Machine not agitating
The most common cause for the agitator not spinning is a broken drive belt. If you are able to turn the agitator by hand, the belt is likely broken. If the agitator cannot be easily turned by hand, there is likely a piece of clothing jammed underneath and the agitator will need to be removed to clear the jam. The video below will demonstrate the procedure for replacing the drive belt in most Whirlpool washers.
Dec 29, 2011 | Whirlpool WTW5500X Washer
I have whirlpool model LSR7233EQO and one belt of cotton stuck under the propeller
If you are referring to something being caught under the agitator, you can remove the agitator easily, by following these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
With the agitator removed, you can easily retrieve anything caught underneath. When reinstalling the agitator DO NOT overtigthen the center post nut. Tighten until snug.
If this is not what you are referring to, please post back and let me know, so I can provide you with better assistance. I hope this is helpful to you.
Feb 28, 2010 | Washing Machines
How do I replace the agitator?
Slide a heavy leather belt underneath the agitator and pull up really hard. It will come loose.
Dec 04, 2009 | GE WBB4500EWW Top Load Washer
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Apr 15, 2009 | Washing Machines
Can't get agitator off of GE spacemaker model WWP 1180G
There is a bolt, ok. Remove the bolt and lift the agitator by reaching underneath it with both hands on each side and pull it up. If it seems really stuck, apply some WD40 and let it soak a bit before trying to pull it again.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Jan 11, 2009 | General Electric WHDSR316G Top Load Washer
How to remove the agitator??
remove agitator cap ,,looking down in agitator removre the plastic seal with a firm yank,,now you can see the agitator hold down nut,,remove that bolt with 1/2 inch nut driver or wrekit,,pull agitator..if clothes is jammin it down take you belt and slide under agitator,,and pull booth ends ,,but away from your fast ,may come up fast..always unplug
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Need to remove Agitator
On a MAV6000, you should be able to pop off the fabric softner cap, remove the fabric softner cup underneath, and finally remove the bolt underneath to lift up the agitator. (rocking the cap back and forth is usually the best method)
Jul 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
281 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
