Question about Delstar DS-3512 MP3 Player
Memory I do not have any files on my player, but yet it says the memory is 95% full and will not allow any songs to be down loaded onto it. How can I erase the memory?
  • devin0810 Dec 19, 2007
    bearshare won't reconized my mp3 player,it say that play for sure doesn't support it
    Problem Solver:
  • 18 Answers
Please follow below steps , 1.right click on mycomputer and select manage 2.select disk management 3.right click on the USB drive and select format. please rate this solution
Posted on Sep 12, 2007
    Problem Solver:
  • 11 Answers
Conect it to your pc and format it some time this happend went you deleted the file in the mp3 player went you formated try to load it again , i hope this be helfull if you have any douht contactme
I have a 4gb memory card i just got it. i have one
Move the song to recieved files. see if that works. all my songs are currently in that folder
Oct 12, 2009 | Apple iPhone 3G Black Smartphone
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
Unable to load MP# files from memory stick on to iPod
You should go to www.limewire.com and downlaod limewire and manually download each song and it'll help you have the music in your i-pod. Yoy can also open i-tunes and connect your i-pod home of your i-pod and check the box that says manually manage songs but that will erase the music you have in the i-pod but will allow you to put the mp3 files on the i-pod.
Apr 18, 2009 | Apple iPod nano
Can't erase songs from sansa
Go into settings, change the USB mode to MTP then connect to PC. Select the player from My Computer, go into the music file and delete the songs. When finished deleting disconnect player restart player, then reconnect to sync new files.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 04, 2009 | SanDisk Sansa e260 MP3 Player
It says formatting my mp3 will erase music on it but i want to get the songs off of my mp3 and put them on my computer is it possible?Will the music then be on the computer and just erased off of the mp3?
Yes, formatting your MP3 Player will erase everything on it other then the required system files.
If the MP3 Player is USB Compatible, plug the USB into the MP3 Player usb port, then plug the other end of the USB into your computer (provided your computer has a usb port). Depending on if the MP3 player needs software to put music on it, it should be easy.
Allow the MP3 Player 1 minute to fully load onto your computer.
Goto:
1) My Computer
2) Find your MP3 Player, should be something like F: Drive or MP3 Player (depends on the kind).
3) Double click on the icon of your mp3 player.
4) If there is music or anything in there, create a folder on your desktop or where ever you wish to move the music.
5) Highlight every song or anything, and right click drag it into the folder you have just made.
6) Make sure no songs are on the mp3 player.
7) Unplug it, check for songs, and if successful, you should have all your songs off your MP3 player and onto your computer! Double check, then you can format it or do what ever you wish!
Hope I helped :-)
Feb 28, 2009 | Nextar MA933A MP3 Player
MP4 LOADING MP3S
format it
and try again to load song
Nov 25, 2008 | JNC Computers SSF-310 MP3 Player
Flash drive is not working correctly
Did you try to download your songs to your media player, or whatever you use to play music on yours? Sometimes if they are not saved correctly you can not just copy them to anywhere.
Jun 30, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Cant erase songs off of mp3 player
The songs/videos you tried to load onto the player are probably not the right format. Ir looks like they transfer, but then you cannot play them. For more details on this, read my "Tips and Tricks" at the bottom of my profile on song formats (2-part article)
Jun 11, 2008 | SanDisk Sansa E280 MP3 Player
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 21, 2008 | Disney Mix Max Digital Media Player
NWZ 615F Blk MP3 player
 “I can’t load any more songs into my mp3 player” or “An incorrect number of songs show up.” (MEMORY/FORMATTING ISSUE)
Sometimes, you can’t load any more songs into your player because, well, there just isn’t any more space left on your player.  Mp3 player product documentation does not actually list the actual amount of memory that you can use in your player, and it doesn’t list the actual number of songs that you can realistically fit on your player.  Every mp3 player needs a certain amount of memory space to operate and firmware upgrades decrease this available space – so, your 2GB mp3 player actually contains only 1.7 or 1.8 GB for music and other media files.  The mp3 player that says “can hold up to 1000 songs” may only hold 400 songs – the product documentation assumes that you are loading a 1-minute song in the lowest possible quality format – not very realistic.  A single 30-minute audiobook, speaker file, or video can seriously bring this number down.
Other times, however, you are experiencing a formatting issue or memory corruption.  If you plug your mp3 player into a computer that has an NTFS file system, and then plug it into a computer that has a FAT32 file system, you may experience this formatting issue (file system/formatting issue).  Similarly, this will happen if you plug an mp3 player into a computer running Windows Vista, and then plug it into a computer running Windows XP (operating system/formatting issue).  Or, if you plug your computer into a PC, and then into a MAC (PC or system/formatting issue).  Or, if you plug it into a computer with Windows Media Player 10, and then into a computer running Windows Media Player 11 (software/formatting issue).
Apparently, if you add too many folders, especially via Playlist, via Windows Media Player, the Mp3 player's file system will become unstable - it can only handle a certain number of additional folders. To resolve the issue:
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Now, when music is transferred, it will be placed in the root directory of the flash memory disregarding the folder structure and allowing all tracks to be seen.
This procedure was designed for Siren Mp3 players, but is applicable to many other Mp3 players. It is not a guaranteed fix for every Mp3 player and every error of this type, but it is certainly not a widely known or reported solution.
Before proceeding with a format or reformat of your mp3 player, check with the manufacturer first.  On many players, a format or reformat along the lines suggested here will override your mp3 player’s native formatting and render your player unusable.  Transcend’s T.Sonic player is especially susceptible to this problem, and should never be formatted.  Also, the instructions below are for Windows-based PCs, not for Macintosh.  There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in some cases by updating the player's firmware or reloading the firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Mar 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Delstar DS-3512 MP3 Player Logo
53 people viewed this question
Top Delstar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
