Question about Dishwashers
Bosch Dishwasher Fails to turn on
I have a Bosch Maxx dishwasher. When I try to turn it on it either will not start at all or the lights come on for a few seconds and then go off again, even though the start switch remains pressed in. There is also a slight buzzing when it does turn on for those few seconds.
  • 2 more comments
  • Sloop Sep 17, 2007
    Thanks for the response. I couldn't find anywhere that would provide a re-worked control board for my model so have decided to replace the machine, as new price for just the control board is a lot. Thanks agin for your help.
  • mbird Dec 01, 2007
    Maytag QuietClean model MDB-8.
    When clean cycle is selected and start/cancel button pressed - all lights go out. Dishwasher will not start.
    This DW is a couple of months out of warrantee.
    I have ensured door is latched. I have tried other cycles, combinations - same result.
    Malcolm
  • meadey May 02, 2008
    Switch on, motors whirls but fails to start.
    Had a similar problem last year and the ever so helpful man from Siemans came out (as the machine was under warrenty) and berated me as a bit of sweetcorn had got stuck in a valve.
    Showed me how to fix it but for the life of me cannot remember. Can anybody help, all I can rememer is the valve was down the left hand side of the machine
  • udpinia Sep 01, 2008
    Have dishwasher SHY56A05. I opened the door when the light indicated clean, then the door does not locked any more. I had repair man for the same problem and he said there is a reset button inside the door. We removed all screws and could not find the button. Can you help?
  • 641 Answers
It sound as a control board problem. you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck!
Posted on Sep 13, 2007
Throw dishwasher out. Never buy a Maytag again.
Posted on Dec 01, 2007
Dishwasher starts, drains, runs 2 minutes, then stops & turns on Clean light
Sounds as if the programmer is not responding maybe time to call out service engineer. Sorry or wash up by hand like I do.
Nov 02, 2017 | Bosch Dishwashers
Bosch maxx wfl 2450 does not drain and does not go into spin cycle
Had the same problem with my Bosch SHX45P05UC/64 Dishwasher. Tried all the solutions - cleaning the bottom, forcing the "flapper", draining manually etc - found on the net, including on YouTube. No dice.
Finally called Sears Service. He walked in, didn't even bother with the dishwasher. Popped open the "vacuum release" (my name for this ;) on the top of the sink (next to the faucet), removed the gunk that had accumulated it, closed the top again, and turned on the dishwasher. Presto! Worked like a charm. He was in and out in less than a minute. Very cool! Try it out before you do anything else. :)
May 03, 2014 | Washing Machines
Water will not drain from my bosch classixx maxx freedom dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 14, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Dishwasher not taking in water
It could be a few things, one of them is a defective water inlet valve, the water inlet valve lets water enter the dishwasher from the main water line, another thing it could be is a defective float switch, the float switch rises up as water fills the dishwasher.
Mar 13, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Exxcel MAXX dishwasher not taking any water
yes u got water on the bottom and there is a switch there first take the water from the bootom
Dec 29, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
894 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
