Trying to take processor out of the case - Computers & Internet
  • 3 more comments
  • woonsx57 Apr 14, 2009
    i know where it is (im a programmer myself) but for the life of me i cant figure out how to get the blasted thing out. i need to reapply some thermal paste to it is all
    it s also an HP Pavilion a510n Media Center Desktop, she's pretty old, just needs some work,
  • woonsx57 Apr 15, 2009
    I'm just trying tyo take it out so i can re Apply thermal paste
  • Binesh Ellupurayil Balachandran
    which is your model?
  • Kenny Wilson May 11, 2010
    What kind of processor do you have?
  • 41 Answers
Usually on the motherboard there is a fan that seats on top of the CPU. If it is intel then the fan clips onto the motherboard. Just be careful and follow the arrows to loosen the fan before removing it. Then replace the heatsink. Make sure when you put it back together that the clips firmly snap and that it goes on the exact same way it came off, otherwise you will not have contact and the CPU will overheat thus shutting your down your comp. This happened to me when I cleaned my CPU fan recently. Hope this helps please leave feedback. Thanks
Posted on Apr 14, 2009
    Problem Solver:
  • 14 Answers
What is the problem? Please include as much info as possible including make and model.
    Scholar:
  • 44 Answers
Are you replacing the processor or just trying to remove it?
When you open the case you will see a large fan seated to the motherboard (depending on the model it can be in different places and at different angles). Under that fan is the heatsink, it is usually screwed or clipped into place. You will need to remove that heatsink to get at the processor.
If you are replacing the processor or moving the old one to a new machine make sure that the socket number is right for the motherboard, and that you apply thermal paste to the processor. Without it you will have overheating problems.
How can I test the motor relay on a Magimix food processor?
Overloading may have caused a thermal protector buried in the motor windings to open in which case the motor will have to be replaced.
Jun 04, 2016 | Magimix 4100 Cuisine Systeme 1268 Cups...
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
THERMAL OVERHEATING SHUTDOWN
1) Clean the inside of the computer. Power unplugged to computer, Anti-Static Precautions used, use a can of air, or two, to clean.
(Compressed air for computers)
2) Computer case open, computer plugged into power, turn the computer on, observe the cooling fans.
A) Processor: A processor may have it's fan sitting on top of the finned Heatsink, which sits on top of the processor,
OR, the fan may be a computer case fan in the Front of the computer, and uses a plastic tuned port to deliver air from the fan to the Processor.
In either case observe the rotation of the fan. See if it seems to be spinning at the correct speed. (RPM's)
See if it spins intermittently. Spins a few times, then slows down, or stops, and then spins again.
3) Check the Thermal Paste.
If the thermal paste in-between the top of the Processor's case, and the bottom of the Heatsink, has dried up, the Processor will overheat.
If a Thermal Pad is used, remove it, fly it at the cat like a Frisbee. They are J-u-n-k.
Clean the top of the Processor's case, and the bottom of the Heatsink, THOROUGHLY, and Properly apply fresh, new thermal paste.
For additional questions post in a Comment.
Regards,
joecoolvette
Dec 09, 2011 | E-Machines eMachines Desktop PC
Why my computer shut down every 2 hours
right click on the desktop click on properties select the screen saver option in this option u can see the power option and selcet never option of turn off hard disk and standby options.
Nov 15, 2010 | Computers & Internet
During recovery my system is stuck on 56%. I tried just to leave it there and 6 hours later is was still at 56%. What to do?
Should be a problem with ur processor
The processor might be detached from the motherboard.
Remove the case and see if the processor is exaclty placed.
Oct 26, 2010 | Computers & Internet
My processor is making a strange noise.The fans are clean and so is the processor. The noise started out with the fans running constant. So we cleaned it and now it makes a quieter but constant noise.
Processor is clean?
Hmmm, are you sure you aren't referring to the Heatsink, sitting on top of the Processor's case?
One example of a typical Heatsink/Fan combo,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3451342&CatId=493
[Typical construction of a Heatsink is a flat plate of metal, with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, and the tall, thin fins absorb the heat from the plate, whereupon the fins radiate the heat away.
A Processor isn't the only hardware component inside a personal computer, that utilizes a Heatsink.
A Heatsink is also utilized inside a Power Supply, (Usually more than one Heatsink), and on graphics cards.
Some high-performance ram memory modules, ('Stick'), may also use a type of Heatsink. (Heat Spreader ]
In your reference, "The fans are clean, and so is the Processor", I hope this isn't an actual reference that the top of the Processor's case is clean.
There Absolutely MUST be thermal paste, used in-between the top of the Processor's case, and the bottom of the Heatsink.
The top of a Processor's case, and the bottom of a Heatsink are not perfectly smooth. A microscopic view would reveal, 'Hills, Valleys, and Pit holes'
These minute imperfections create air pockets, in-between the top of the Processor's case, and the bottom of the Heatsink.
Air is an Insulator, not a Conductor.
Thermal paste fills these imperfections, and is an excellent conductor.
Conducts heat from the top of the Processor's case, to the bottom of the Heatsink.
If your Processor has a thermal pad, (Usually whitish in color, and looks just like the description. A flat Pad), suggest you take it off, and throw it at the cat.
Thermal pads are Junk!
Thermal paste, with a one Processor application, averages around $5.
NEVER run a Processor without thermal paste, and ensure that the top of the Processor's case, and the bottom of the Heatsink, are Perfectly clean.
(Computer unplugged from power, Anti-Static Precautions observed. A Processor is the MOST susceptible hardware component in a computer, to Static shock)
I use an old credit card to scrape the old thermal paste from the Processor, and Heatsink. It's plastic so it won't scratch, nor transfer Static electricity.
I then follow with Q-tips dipped in Isopropyl Alcohol.
91 percent, (91%), alcohol is best. 70 percent will do in a pinch.
I advise not using 50/50. (91 percent alcohol, 9 percent water. 70 percent alcohol, 30 percent water, and so on)
Isopropyl Alcohol is also known as Rubbing Alcohol.
[CAUTION!!
Isopropyl Alcohol is Extremely Flammable!
Use in a WELL ventilated room with no sparks, or flames present ]
It may take a few Q-tips, as the thermal paste residue may be a sticky mess.
HAS to be Thoroughly clean, before applying new, fresh thermal paste.
Correct method for applying thermal paste, (Also referred to as thermal grease),
http://www.hardwaresecrets.com/article/274
Ensure that the Heatsink is sitting FLAT on top of the Processor.
Slightly tilted will NOT work.
It is for this reason I dismount the motherboard from the computer case, and from a side view, look across at the mounting of the Heatsink, to the top of the Processor's case.
No daylight must be showing in-between the top of the Processor's case, and the bottom of the Heatsink.
The Heatsink must be sitting perfectly flat, on the top of the Processor's case.
The only time I have heard of a Processor making a noise, is when it is close to failing. (Quit, Die, Kaput)
The noise may be Taps, or a french(?) retreat song, that escapes me at the moment.
(Perhaps it's a song from Bach, or Trachosky, or Mozart)
Some computers use a computer case fan in the front, to push air through a plastic shroud, which encases the Heatsink.
Most computers use a Fan on top of the Heatsink.
In this case, are you sure the wires that provide power to the Processor fan, aren't being hit by the Processor fan blades?
Also, have you checked the Processor fan for bad bearings?
Gently lift up on one side of the Processor's fan blades.
Does the fan seem tight in the bearings, or loose?
If the bearings are bad, it will allow the fan's center hub to tilt to one side, and scrape.
Sep 19, 2010 | Acer Computers & Internet
Processor
Not showing on the screen in the sense, is the Operating System [assuming XP] system properties window not showing the processor details? If its the case, generally some processors will have some issues with the Operating system.You can fix it by downloading some "hot fixes" from Microsoft.
Try this: 1.Open the "run" dialog box [Windows key + R] 2.Type "dxdiag" [without quotes] 3.Press enter. 4.You will be able to see the processor configuration in that window.
If not succesfull, please post. I will suggest another method.
Oct 29, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computer Build Problem
Try taking out the mobo and ps out of its casing, lay it on a table, hook things together and power it up. I had some problems before caused by mounting studs or try insulating all stubs from the mobo. hope this will help.
Apr 09, 2008 | Intel Motherboard
Cannot continue
Well...
I am VERY confused by your description here. I can't tell if you're talking about the processor as it appears inside of your computer itself...or if you're refering to the processor as it appears in Windows.
Please try to be a little more specific with your explanation. Go step-by-step in what you are doing and what is happening.
Cyryl
Oct 31, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
CPU Hung
Hello Wolf, It sounds to me like the processor fan is not working correctly. When you put a load on the processor like programs, movies or games, it overheats and hangs up. Try taking a fan, and with the side removed from your case, have the fan blowing into the case, and try a movie or a game. If it does not hang up, replace the processor cooler and fan. Please let us know how it works for you, and if we can help you in any other way. Best regards, nightdiver
Oct 08, 2006 | Intel Celeron, 1.8 GHz Processor
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
