Question about T-Mobile MDA
MDA doesnt charge or turn on..i put the charger in but i dont see any changes yet..idk, but i need help..
  • Producer Sep 13, 2007
    oh, but does it matter if i havent used the phone in a while, or wouldnt the battery exploed wen i do that..i put the charger in 1 day an charged it for a wwhhile, an still nothin happended...but ima try that now an see wut happens..keep me posted with more solutions..
    matter fact, wut happened with yours..??
  • 4 Answers
Throw the phone battery into a zip lock bag and put it in the freezer for about 12 hours...then put it back in the phone...should work just fine! same thing happened to me
Posted on Sep 13, 2007
SOURCE:
My phone is not powering on when i plug the charger in it has a green light in the top right corner but its not turning on when i press and hold the button on the top left
try taking the battery out and while holding the power button in put the battery back in, if you still get nothing on the screen try doing the same , holding the power button down while you insert the charger.
If a tri coloured screen appears you will be able to reflash it, if it doesnt appear, then your battery is dead and it wont charge no matter how much you try, the MDA(or wizard) wont charge the battery, unless windows is running, i would recommend you buy a new battery, they are cheap enough
NOTE!!!
If the battery is very low but you can get the multicoloured bootscreen, i would not advise flashing it as you have no idea of how much charge is in the battery, if the battery fails during flashing you wont have a phone anymore
Dec 29, 2009 | T-Mobile MDA
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
Apr 07, 2009 | T-Mobile MDA
Installing sim card in sidekick II
the sim card goes on the bottom of the phone under the rubber thing (idk what to call it) you need to lift it up and you will see a pictuer of hoe to pu in your sim card and for the battery idk
Jul 05, 2008 | T-Mobile Sidekick II
MDA will not power up.
another this to try is get a new battery.
mine had the same problem i would try to charge and nothing and it would turn on for about 30 seconds then turn off and i tried putting it on a charger within those 30 seconds but it wouldnt take a charge.
i got a new battery theat had some charge in it and it worked great! alot of the time thats all you need it a new battery
Mar 15, 2008 | T-Mobile MDA
Mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
Jan 09, 2008 | T-Mobile MDA
Battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
Okay, I searched and searched until I found a solution that worked for me. I tried the USB thing, I got my phone to turn on once, but never to charge. Here's what I did:
(Do this at your own risk)
I zapped my battery with a 9v battery. One wire on each terminal and then held it to the MDA battery (positive to positive, negative to negative) for about three seconds. I did this about five times. (Don't let the wires touch while they are connected to the 9v battery.) I IMMEDIATELY plugged my phone into a wall charger, NOT my computer (The computer wouldn't charge my phone). As soon as it was connected to the wall charger, I turned it on. After starting up, the orange light came on, and it started charging. I was skeptical about this solution at first, but trying everything else I resolved to do this and then if it didn't work buy a new battery, but it worked and my MDA is charging as I'm typing. The original ideal came from a post on the xda-developers website by dew1989. I added the additional steps that got my battery charging again. I hope this helps!
Dec 04, 2007 | T-Mobile MDA Compact Smartphone
Phone does not charge battery
Use the factory charger, i had that problem becuz i was using a razr charger, if nothing works call tmobile and tell them u r in warentee and u want to do a hanset exchange
Nov 22, 2007 | T-Mobile Wing™ Smartphone
T-mobile mda
buy a battery new
Sep 14, 2007 | T-Mobile MDA
MDA (T-mobile)
Make sure that your mda is being charged with an original charger
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
T-Mobile MDA Logo
79 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
