Question about InFocus ASK-Proxima C170 Projector, Factory Refurbished Multimedia Projector
Can´t power on my projector
My projector does not power on. I have replaced the lamp but no luck. What can be wrong there is no letters coming on the display, can the problem be blown fuse somewhere?
  • helgij Sep 12, 2007
    Hi Dodgecharger.
    Thank you for your input. Can you send me the pic that you have or tell me the capacitor number on the circuit board.
    Thanx
    Problem Solver:
  • 18 Answers
Please check the power cable then fuse.
Posted on Sep 12, 2007
    Novelist:
    Champion:
  • 254 Answers
Some Proxima projectors had power supply problems, which resulted in either a dead unit, or, in the early stages of failure, might take a while to come on (maybe even 10 minutes or so). At the college where I'm employed, we've had 4 or 5 of the DP2000X models with this problem. The cause was a bad electrolytic capacitor in the power supply, namely a 47MFD/25volt unit, in the primary side of the circuit. I have pics of this circuit board. Another Proxima model had a shorted ceramic disc capacitor, and a blown fuse. If you have someone who is technically savvy, they could check your model for such a problem
  • Merwyn Bolles
    Merwyn Bolles Sep 13, 2007
    helgji:
    Send me an email at dodgecharger4404@netscape.net, and I will then email back the pics (I'm heading out of town for a couple of days, so it might be Monday before I can reply). Please note that the Model you have may not have the same power supply unit (though the basic design might be similiar). Component values & locations would thus be different.
    Chansn's suggestion should be checked first- if you have a blown fuse, usually some component failure has caused the poofed fuse, and replacing the fuse without finding the other defects will only blow it again, and possibly poof some additional parts.
    Also, if you have the unit apart, and don't know where the power supply board is at, you could send a few pics, and I might be able to ID it for you, and maybe make a suggestion or two as to what to try.
    Thanks,
    Dodgecharger
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
Lights flashing
Replace the lamp. The lights flashing will also indicate what is wrong. Watch how they flash. Go to the manufacturers website and they way they are flashing indicates what is wrong (ex. 3 quick flashes, long continuous flashes...etc.) When you change the lamp reset the lamp counter in the menu and clean or replace the dust filters as well.
Jan 11, 2014 | Sanyo PLC-XP200L Projector
Rollei 35A slide projector - halogen lamp problem
Most all projection lamps of 1970 vintage are still available on the internet. There should be a 3-letter code on the lamp. Try using Google to search that lamp code. There are multiple vendors in the USA that have an amazing inventory remaining. Good Luck !! Jim
Nov 19, 2013 | Office Equipment & Supplies
I want to rest the Lamp timer of Toshiba Projector TDP-TW95 after replacement of New Lamp
hi
reset ur lamp timer through the following procedure
p { margin-bottom: 0.21cm; }
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
ok
Jan 06, 2011 | Toshiba TDP-TW95 DLP Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
Dukane starfire 3010 overhead projector has no power, fan wont even come on
Power supply is not coming on or interlock on lamp door is failing to close not allowing power to come on. good luck.
Mar 02, 2009 | Dukane Starfire...
No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Jan 02, 2008 | Hitachi CP-X260 LCD Projector
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Dec 24, 2006 | Canon LV 7345 Multimedia Projector
372 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
