Question about Acer Extensa 5420-5687 Notebook
Keyboard only on screen key board works
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    check ebay for new keyboard
    may be this will help
    http://www.cyfinity.com/2008/07/acer-asp...
My samsung n150 keyboard not working and my screen is broken what can i do to connect to external monitor
Dear Ronald
Pl. remove the key board connector from the main board and tape it.. Connect the external key board and monitor to its port.
That will work. It will better to disconnect the internal display connector.
Thanks.
Feb 22, 2015 | Samsung N150 Notebook
My delete key is not working on keyboard but fine on screen key board on HP mini
tap the iPad on a bench lightly and while pressing on the broken button slide your finger across the button lightly trying to loosen anything under the button
Jul 27, 2014 | HP Mini 1000 Netbook
Key board is not working checked the battery only...
Try another key board it could be bad or try a usb keyboard
May 20, 2010 | Computers & Internet
Shift key error
dear sir
good day
you can use the caps lock key instade or you can use the ms onscreen key board from accessories then ease of use then chose the ms on screen key board or by the end of the day you can buy a new key board for that :)
thank you
Dec 24, 2009 | Computers & Internet
My print screen button is not working
does the mouse work,you may want to replace key board key boards are pretty cheap.
Nov 25, 2009 | Acer NSK8458AN Keyboard
When I am typing and I press the d key in lower case, the cursor moves back to the home position. When I press 2, 24 comes up on the screen and when I press 3, then 35 comes up. Acer is not much help. It...
First you try to clean the key board with a brush. If there is dust inside there is a chance for malfunction. or you can change the key board. Key board is not much costly.
May 04, 2009 | Computers & Internet
Water damage to my curve, key board does not work, all else does
Hi
I'm looking for a new board for a blackberry curve 8320 since I had to blind the charger access so I'm wondering if you can provide me with the proper price of new board or secondhand
Jan 11, 2009 | AT&T Blackberry Curve 8300 Smartphone
KEYBOARD PROBLEM
My Blackberry 8310 curve key board is not working properly. When I press 5 nothing happens on the screen, when i press 4,7,and some of the letters dont work at all till i move them arround .
Jun 26, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
Acer Extensa 5420-5687 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
