Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens will not open to take photos screen says to turn camera off and on.
The lense on my sony cybershot will not close or open and it says to turn camera off and on again
  • 98 Answers
You have an defective lens assy is it fallen on the floor o ris it shove
Otherwise there some contamination in the gearbox of the zoom assy It can only retosred by an repairshop. They clean the lens assy or change it.
Regards,
Rob NL
Posted on Apr 19, 2009
Sony Cybershot bent lense
Sorry to say that although your camera is in warranty but it does not cover under warranty according to the terms and condition, you just have to visit nearest sony service center to get estimate for complete lens assembly, it must be replaced by new one. You didn't mention model number here that i can tell you the cost and part number of lens assy.
thanks for using fixya.
Oct 18, 2009 | Sony Cameras
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
My sony cybershot dsc-p200 lense is stuck.
Sony Cybershot DSC-P200 worked great then the lens stuck in the open position.
Read on this site some one suggested gently manipulating the lens and tapping it then turning it on. It worked!!
Apr 07, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony cybershot DSC-W50 lens problen
thats normal.
it just doesn't have enough power to bring the lense back in.
once you charge your battery and turn it on the lense will automatically come back in and then out for you to take a picture.
Apr 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck open
I have to agree with one of the comments previously posted. I too had a Sony DCS-S700 and the lens was stuck open. Whenever I turned the camera on, the Sony Cybershot logo appeared and dissappeared, turning the camera off. I noticed the lens was crooked, so I moved it in the center direction and the camera worked again.
Mar 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
193 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
