Question about LG CHOCOLATE VX8500 Cellular Phone
Display is blank unless heated up.
LG VX8550 screen goes blank. I can revive it by heating it up with a hair dryer, but immediately goes blank again after it times out. No water damage. Confirmed it has latest updates on software and firmware. All other functions work.
  • bna311 May 23, 2009
    i have the same problem. im pretty sure it started happening when my phone got slightly moist; no more moist than it has gotten many times before. it started working again for a little while and its been on and off for the past two weeks. insurance wont pay for it so im hoping itll resolve itself. I havent tried the hair dryer thing, mine just seems to randomly start working again.
  • 89 Answers
The hardware in the phone has most likely melted and only works when heater now... DON'T heat it up, you're making it worse!!! Take it into a repair center and they can try to fix it... If not it will most likely have to be replaced. I have this same phone and I've had to have mine replaced 6 times.
Posted on Apr 14, 2009
I have a LG (DLG0452W) gas dryer. It will tumble, but no heat. The light bars by the timer display are flashing orange instead of green. What could be the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | LG DLG0452W Gas Dryer
Few days before, my blackberry8310 falldown in the watersink.i put the heat lamp for some time.now phone is taking the charging but display are not present on the screen. pls solve the...
Friend,
With the heat on, you may have burnt something inside. Whenever you get your phone wet, always remove the battery and SIM immediately and use the hair dryer without heat. Just plain dry cold air. Blow air into it for a very long time to remove all traces of water. Then power on the phone. It may work. You still may have a chance to save your phone. Do blow air through the phone.
Dec 27, 2010 | Cell Phones
The screen on my LG VX8550 (chocolate) doesn't work
the screen is not the one that is faulty, but flex.
There is a flex the connects the screen with the phone board. This flex usually worns out as a result of constant open and close of the slide.
Once you have the flex replaced, your screen will display again.
Good luck.
Mar 06, 2010 | LG CHOCOLATE VX8500 Cellular Phone
WHAT IS 8.8.
8.8. indicates a display pad problem. It happens a lot this time of year. The cold weather causes a problem with the keypad, espicially if the machine is in a garage or a basement. One option is to replace the keypad, but a more immediate solution is to place a heating pad over the display panel. After 10 the 15 minutes the pad will warm the display enough so that it will work.
Jan 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
My tv turns on properly but after a few minutes it goes blank
you are having a heat related issue and the component or parts are failing. using a hair dryer blowing into back of set will make it black out and a portable fan should cool it enough to come back on. unless you know a good cheap tech, repairs are costly. i left the business when t.v' s became disposable.
Sep 21, 2009 | Panasonic CT-32D10 TV
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Phone had water damage now it won't work
If you can open the casing ,using a hair dryer on low heat ,fully dry the inside circuit board.Then try it.
PLEASE RATE THIS THANK YOU !
Jun 09, 2008 | Samsung SYNC SGH-A707 Cellular Phone
LG 1715S faulty
I can confirm the number 3 solution. I have fixed a bunch of these now.
Replace capacitor C202, 680uf 25V. It is usually visibly damaged. It should be a low impedance type, often known as "suitable for switch mode power supply".
May 25, 2008 | LG Flatron L1715S 17" LCD Monitor
LG CHOCOLATE VX8500 Cellular Phone Logo
240 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
