Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Electric Dryer will not get hot
Can you assist with the issue of my Whirlpool Duet Electric Dryer not getting hot. It spins and the vents out are clean.
  • 625 Answers
Re: Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Posted on Sep 13, 2007
0 characters
3 Points
I keep getting an F7 error message when using my Whirlpool Duet electric dryer and then it just turns off
F07 Motor Control Unit Error
Description: The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Check or Repais:
- Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
- Check the MCU
- Check the Drive Motor
- Check the Wire Harness
Hope helps.
Sep 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to unlock my duet whirlpool dryer 2004 it says control lock
Thanks for using FixYa. To unlock the controls you'll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Sep 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer turns on and spins but no hot air,,,just cold what's wrong?
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No heat in whirlpool duet dryer replaced the thermistor still won't heat what next?
You have this listed under "Front Load Washer" and don't explain which type of of dryer you have (Gas or Electric). I'm assuming this is an ELECTRIC dryer, since you mentioned a thermistor. The following link will explain how to troubleshoot your dryer no heat problem:
The symptoms of a dryer no heat problem are, the dryer drum will still spin, the blower fan runs, and all indicators function, but the dryer does no heat. If this is the problem you are encountering, then the link I provided for you should help you find your cause.
The first step to troubleshooting this problem is to check the voltage at the wall receptacle across the two hot leads (the two large slots in the receptacle - each leg to neutral reads 110-120VAC). A reading across the two hot leads should yield 220-224 VAC. If the voltage is incorrect, this can cause the heating circuits to fail, but allow everything else to work. I have seen where one leg of the 220VAC circuit is tripped or not working at all and causes the wall receptacle to read 1/2 the normal voltage that is required. This could be a problem with the circuit breaker panel or wiring in the wall receptacle. The heating circuits require 220VAC to operate, while the controls and drive motor only use 110-120VAC. If the voltage is correct at the wall, check the voltage at the terminal block in the back of the dryer. This is where the power cord attaches. If the voltage is correct at the terminal block, the problem is in the heating circuits. If the voltage is not correct at the terminal block, you may have a bad power cord.
NOTE: Please ensure you UNPLUG the dryer when replacing any internal components. Dangerous voltages are still present with the unit turned off.
Now...what controls the heating circuit in a Whirlpool manufactured dryer is the Thermal Cut-Out (TCO), the Hi-Limit Thermostat and the Heating Element. I'm assuming you replaced the TCO(?). If you did, it is recommended that you replace the TCO along with the Hi-Limit Thermostat. Failure to do so can result in premature failure of components you may have already replaced.
The link I provided explains all this. Please read through the information I provided and let me know if you have questions. If you require further assistance, please let me know before you rate the solution. I hope this helps you resolve your problem.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
what shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WHirlpool duet washer is stuck on "controls locked"
we ended up holding the drain/spin button for a period of 15 or so seconds and the issue resolved.
Mar 30, 2008 | Kenmore 42822 Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
819 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
