Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba laptop a100 sghutdown after 2 mn even when in the bios menu. fan seem to be working fine. cannot reach the login screen anymore.
  • 71 Answers
It is very possible your harddrive is wiped out...try getting a new one.
Good luck
Posted on Apr 13, 2009
I have a similar problem with my toshiba equium A100 - 027. Power is reaching the machine but the screen is blank. the machine was working fine when it was closed down on Monday. What do I do?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 03, 2011 | Toshiba Satellite A100-S8111TD Notebook
I have a tecra m2-s730 that displays the boot screen then back light goes out but you can still see image..what could be problem
1) test it to an external source like a tv, or external monitor through the vga ports, svideo ports. If promblem is solved, and everything seems to be going normal, then your screen is history, bad backlighting and needs screen replacement. 2) Bootup screens seems to work fine, ( like it has backlighting and light all work fine and normal) but when it turns over to loading your o/s and it get dark even with a external monitor, then it's a driver issue or your vga chipset is bad and you will need to replace your motherboard, ( in this case it is best to buy a new laptop). 3) Bios error issue, bios has become currupt somehow, you can try loading default value given in the exit tab in your bios menu. Load and save and exit. See if it works, if not your VGA chipset is screw, and motherboard will need to be replaced to fix this issue.
Jan 30, 2011 | Toshiba Tecra M2-S730 Notebook
Laptop wont power up..... hard drive light blinks... checked hard drive and it fine... i tryed with 3 different power cords/ power supplies....
You checked the hard drive and did it boot another computer?
Do you achieve POST and get to the BIOS menu?
If you do get that far, then you have a boot sector fault, if you don't reach POST then you have a Motherboard fault and it will require service with a Toshiba agent.
If you have a boot sector fault press F8 as the BIOS screen is leaving the display.
Choose Recovery and follow the prompts.
Hope this helps.
Nov 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100 PSAA2C video boot
have you tried installing or running the drivers disc for your laptop right after the windows installation without restarting it first? that might do the trick... it's either the driver for your laptop's board/ chipset or the vga driver...
Nov 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
The 'Fn' key doesn't seem to work anymore. Need to brighhten my screen
go into the bios ( F2 or Delete or which ever key it states when the computer starts up to get into the bios )
Ensure that the FN key is not disabled in the bios, if it is re enable it and try it again.
Otherwise I would call toshiba and see if the warranty covers it still if not you may have to get them to repair it or call around laptop shops to get them to look at it - may require to replace the keyboard .
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite A100 LE4000 Turns Off Randomly
there must be still a problem with your current cooling system. try cleaning up your laptops fan. cpu gets heated up very easily even if you turned it off for a while. you can do this by unscrewing the parts, the inside must be pretty dusty or something. this also happened to me but from a different unit.
also, try checking for the latest bios driver for your laptop and to be sure, download it on toshiba site itself. because latest drivers for your bios also manages the control of your cpu fans.
if you could also get access to your systems cooling options in bios, try checking if your cpu's temperature are doing fine.
but i prefer you cleaning up the inside fans as well. hope this helps.
Feb 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Laptop doesnt display anything
if there is no display whn u press the start button then your motherboard is screwed. i had this problem with mine too. I got it replaced fro free as it had a warranty... anthing more contact babu_aero@yahoo.com
Jul 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
did it ever read from the CD drive or was it like this out of the box? I have had this before. There was a hair/dust on the lense of the laser...DO NOT use your fingers to clean it off. You must have a proper lense cloth to whipe it (cloth for eye glasses or micro fiber cloth for monitor screens, do not use any other cloth)
Get back to me with your answer.
Wayne
Jan 03, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satillite A100 "TBX Error"
This needs BIOS Reprogramming. Go to the nearest service station for the Chip to be reprogrammed.
Sep 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
