Question about Kyocera KM-1505 Copier
Troubleshoot/repair of Kyocera KM-1505
My Kyocera KM-1505 copier print out is blurred and it prints but some data in the original was not print or blurred
  • Anonymous Mar 13, 2014
    CONNECTION CABLE OF KYOCERA KM 1620NAME THE CABLE THAT CAN BE USED TO CONNECT THE KYOCERA COPIER TO THE COMPUTER TO PRINT
  • Anonymous Mar 16, 2014
    robleme ap
  • 682 Answers
1-apply fesh paper it must be out of humidity and wet.
2-confirm smoth motion of optical system.
3-deformed press roller-replace it..
4-paper conveying section drive problem-check the gears and belts and if necessary grease them.
Posted on Mar 05, 2008
  • 163 Answers
There is moisture on the drum of your copier or problem in your drum unit
Posted on Sep 13, 2007
6ya staff
SOURCE:
How do i fix J98 error in Kyocera KM-1505 copier
This is from the users manual:
"Open the drawer and left cover and check for any misfed paper. If the same indication appears, contact your service representative."
http://www.instructionsmanuals.com/u2/pdf/fotocopiadoras/Kyocera-KM1505-en.pdf
Jan 16, 2015 | Kyocera Office Equipment & Supplies
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Apr 08, 2013 | Kyocera Mita Office Equipment & Supplies
DISCULPE REQUIERO SABER EL ERROR A 400 DE MI COPIADORA KYOCERA MITA KM 1505, todo opera casi normal pero me bloquea con ese error a 400
bonjour ,j'ai une photocopieuse kyocera km 1505 et me marque le message erreur A400 ,y a t 'il quelqu'un qui pourrait me dire quesque c'est ce message là je vous remercie d'avance
May 02, 2010 | Kyocera KM-1505 Copier
Error C-0150 back up memory of kyocera KM-3540
http://www.eserviceinfo.com/downloadsm/15534/kyocera_km1620/2020.html
http://www.fixdevice.com/smanuals/file/34223.html
Repair manual above.
http://www.fixdevice.com/smanuals/file/34229.html
You mention two, KM-1505 & KM-3540 here is the generic manuals for both.
www.feedroller.com/Store/Service%20Manual/KM_1505P.PDF
Service manual above this is the fix manual above.
Backup memory read/write problem
(engine PCB)
• Read and write data does not match. Defective engine
PCB.
You have a bad board in the printer it must be replaced.
Apr 08, 2010 | Kyocera KM-1505 Copier
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
How to clean the printer inside
You can use an aspirator to clean the printer inside, and if you have a little experience you can clean the blade inside the cartridge with isopropylic alcohol, and the drum too. How many times was the cartridge refilled?
Oct 14, 2008 | Kyocera KM-1505 Copier
Kyocera KM-1505 Copier Logo
314 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
