Question about Twinhead DURABOOK N15RB Notebook
Sometimes the screen goes blank. It seem to be alot looser now and its only 3 years old. It doesn't stay completely up unless I keep adjusting it
  • frankm205 Apr 13, 2009
    Yea, sometimes if I open and close it 2 or 3 times the screen comes back
  • 71 Answers
There is a ribbon inside ontop of your screen that may have come loose, the only solution is to have someone qualified to fix that...but, if you think that you can do it yourself, you can try that. the screen opens by removing the 5 screws in front of the screen.
Does your screen improve when you move your screen or shake it a little?
Posted on Apr 13, 2009
  • Hernan Erazo
    Hernan Erazo Apr 16, 2009
    you might also be having problems with your backlight module. Which either way, you have to have that repaired by someone who knows how to repair them.
    Good luck
Hi, i have a samsung notebook, recently it has started to go into a blank, white screen, sometimes it stays like that sometimes it goes on and off. i've tried to install a new anti virus software but...
I would reboot into safe mode, then run your anti-virus/anti-spyware software again, then try rebooting in regular mode and see if that fixes the issue. It sounds like it could be a hardware issue, though... possibly a loose connection or faulty screen, if the virus/spyware search doesn't pan out.
May 18, 2011 | Computers & Internet
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Monitor goes fuzzy and then blank
Contact HP at 1-800-HP-INVENT
-=/ Daft Tech /=-
Oct 22, 2009 | HP Computers & Internet
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Dell Inspiron 6000 about 3 years old. When I boot up, sometimes it goes through the early Windows XP screens and then goes to a blank screen. It indicates that activity is going on but cannot see it on the...
The screen cable is most likely damaged. Try connecting an external monitor. If it works, you need to take the computer to a repair center to have the cable changed.
Aug 24, 2009 | Dell Computers & Internet
Tv goes blank
The effect you described sounds a lot like a failed solder joint.
There are points on the circuit board that are subjected to heating and cooling each time the set is powered up, then down.
The solder joints near these areas can fail from metal fatigue as will any metal that is forced to expand and contract repeatedly.
These fractures are minute and can often only be seen under magnification.
Once found, they are simple to fix; removal of the old solder and resoldering will restore electrical contact in seconds.
If you can find a gray-haired tech nearby who is retired, maybe early since repair is a business stagnated by cheap labor in Asia, he/she will know where these areas are and can robably get rid of your lottery-like operation.
Or, if you have way too much time on your hands and are willing to buy a decent soldering iron and dig into the guts of your set, you can probably find the problem yourself.
While semiconductors do fail (sometimes for the same reason), since the set does sometimes restore itself, it isn't likely that any of those has died.
I would be torn to toss the set if it is otherwise OK for the simple reason that if repaired, it may outlast 80% of those bought in the last 2 years.
It is amazing the number of problems that are happening on new, sophisticated sets and it is traceable to lousy quality in parts and assembly.
I have one LCD set I will probably junk this year that is only 2 years old, flawed when I bought it new, and has a failure producing a vertical black stripe that would require replacment of the $4-500 panel.
Junk - Specifically, WALMART junk.
Jul 12, 2008 | Zenith B32A24Z 32" TV
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Twinhead DURABOOK N15RB Notebook Logo
100 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Lee Durbin
Lee Durbin
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
