Question about Panasonic AJ-D230H DV/Mini DV VCR
RCA TV to Panasonic DVD
How to connect RCA TV To Pan. DVD
  • 35 Answers
Does the RCA TV have an aux video input ?
if it does just get a BNC (male ) to RCA (female) adapter and a RCA cable
if not, you can go to an electronics shack or online seller and purchase a modulator..
a good modulator should take in Left and Right Audio and Composite video signals and modulate them to TV channels 3 or 4 (usually selctable with a switch)
Ed
Posted on Apr 14, 2009
Correct placing of leads from dvd player into back of TV?
If you are using RCA jacks to connect from the DVD player to the Television (RCA jacks are the connectors that have a white & red colored end for right and left speaker sound and another yellow end for video) connect one end to the back of the DVD player where it says "out going connections" and the other end to the television in the "incoming" connections. Remove your television antenna from the tv to the DVD player. The antenna signal goes to the DVD player and the Dvd player sends the picture outgoing to your tv set.
I hope this helps?
Sep 12, 2011 | Panasonic Televison & Video
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My dvd player was unhooked from my tv during a move. i no longer have the dvd manual. apparently I am connecting something incorrectly, because I have audio but no video. can you help with a verbal or...
The DVD player and Tv set connections are made in ur tv,by what kind set up?Like by a RCA components cables Y,R,W RCA cable?Just follow the DVD player output holes hook up RCA cable Y,R,W to the DVD player out holes hookup to tv set input holes like Y,R,W input holes.Check the RCA connections cables pull out and re connected in those holes a couples times sometimes old equipment must do that for ensure contact are made.Might have a damage set of RCA cable set.Might have replace another RCA cable set.Or ur setup using a S-video cable set and used a RCA cable R,W cable only for audio only?Than S-video cable probally got shorted must be replaced.
Aug 04, 2011 | Panasonic Televison & Video
Will a dvd player work with a Panasonic PV-M2023 combo TV VCR, built in 1993? We connected a DVD player but haven't been able to get it to work. We have the original remote control.
I see that it does have RCA input (Yellow, white, red) on the reverse of the TV. Connect the DVD via RCA cable to the corresponding color connection, place the TV in "Vido" or "aux" mode. this is usually done on the remote from an "input" button, or it can also be called "game," "video," or "aux."
Upon putting it to this after connection of the DVD player, you should see the DVD players home screen. You should be set to enjoy the DVD player.
Jun 28, 2011 | Panasonic Televison & Video
Have a dvd player connected and cannot switch my tv to it the tv tells me to connect the cable how do i get the dvd player to work
use RCA av/in cable from dvd to your tv. and press channel 1 to channel 0 to come out your video input.
Feb 05, 2011 | Panasonic AG-520G 20" TV/VCR
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Do not know how to connect the tv, theatre system to the cable box.
have you got the cable box video out (yellow RCA) connected to the video input on the panasonic? What kind of tv is it? Is the tv displaying the input that the panasonic is connected to? If "progressive" is selected, it will not display on a standard definition tv. Does it matter which mode the panasonic is in (CD/DVD)? I guess I'm just asking for more info ;-)
Foamesh
Jan 27, 2008 | Panasonic SC-HT680 System
Panasonic AJ-D230H DV/Mini DV VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
