Question about Maytag PYE4558A Electric Dryer
Thermal fuse in Maytag PYE2300AYW not plugged in
I replaced the high limit thermostat in my Maytag PYE2300AYE dryer today and the repair kit came with a small thermal fuse as well. I found the original fuse next to the heating element, but it wasn't plugged into anything. It has two leads on the back and looks like it should be plugged into something! I looked around the dryer and found no dangling or unplugged wires. Should the fuse be plugged in? The dryer is working fine, but I thought this looked wrong.
  • 686 Answers
NO. YOU ARE OK YOUR DRYER SHOULD ONLY HAVE A HIGH-LIMIT AND A CYCLING THERMOSTAT. YOU CAN LOOK AT YOUR DRYER PARTS AT www.repairclinic.com ENTER MODEL NUMBER SCROLL DOWN ALL THE WAY CLICK THE RED 100 AND SEE ALL.
Posted on Apr 13, 2009
  • James Chandler Apr 13, 2009
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Oct 30, 2012 | Maytag Pye2300ayw Dryer Door Switch...
I have a Maytag PYE2300AYW, I am on my third round of replacing the High Limit and Thermal Fuse. I am at a loss on what could be the main factor for this. It almost seems as if the heating element is...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 09, 2011 | Maytag Dryers
Dryer does not work at all on any setting.
The thermal fuse might be blown (just fixed my PYE2300AYW last week - I assume they're similar enough). Easy to check - pull the wires off the terminals of the thermal fuse, put an ohmmeter across the terminals. If no continuity, it's blown and needs to be replaced.
Also replace the high-limit thermostat at the same time, since it wasn't apparently doing it's job (for mine, the 2 came together in a kit, about $20 - fairly standard, so yours very likely uses the same, but you should check it).
You should be able to find a picture showing where the thermal fuse is and what it looks like by googling "PYE2300AY thermal fuse".
And, while you have it open, clean any and all lint out from around/ over/under the hearing coils - that may have contributed to the overheating.
If you DO still have continuity across the thermal fuse, then it's something else, but from what I've read, that's likely the culprit.
Jun 28, 2010 | Maytag PYE2300AY Electric Dryer
Model #PYE2300AYW Dryer. Changed therm fuse. Died in 5 loads. Changed therm fuse/Hi limit. Died in one load. This is a fairly simple machine. Could op thermostat be taking all these out? Tnx
Your lint trap and/or ducting could be blocked. This will cause the machine to overheat and the thermal fuse shuts it off before it burns your house down.
Jan 30, 2010 | Maytag PYE2300AY Electric Dryer
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Replacing a heating element on Maytag Electric Dryer
Hank,
if you have all those parts , i would indeed replace them all. it will allow your entire heating circuit to strat fresh
just ensure all your paddle connections are tight
but check your heater for continuity too
Oct 21, 2009 | Dryers
Where is the thermal fuse located on pye2300ay dryer
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Heater is located in the left rear corner behind the tub. High Limit thermostat sits atop the heater and thermal fuse is located toward the right side of the can containing the heater.
Kit number LA-1053 contains several thermostats and fuse. replace all parts in the kit.
Sep 23, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE4558A Electric Dryer Logo
439 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
