Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Cleaning how do i clean a plasma or flatscreen that is in a smoke filled enviornment?
    President:
  • 1,077 Answers
It is recommended to use a simple alcohol solution to clean an LCD or PLASMA screen. This solution is made up of 1 part distilled water and 1 part 50% isopropyl alcohol. Be warned that isopropyl alcohol is flammable.
50% isopropyl alcohol is very common. If you find 70%, 91%, or 99% isopropyl alcohol, adjust the formula to use less alcohol and more distilled water.
By mixing these two in a bottle, you will produce a model cleaning solution. Remember not to use tap water -- only use distilled water.
Do NOT use tissues/Kleenex to wipe your screen. That is as ineffective, because they will leave little tissue particles all over your screen . Try and find some microfiber cloth to clean your screen. Cloths that come along with prescribed glasses are usually good.
You may want to clean the rest of the actual screen before moving onto the LCD or PLASMA part. First dampen the cloth with the solution. You should never spray any sort of liquid directly onto the screen. Wipe the screen gently from top to bottom and wait for it to dry.
Be careful not to let the cleaning solution leak into the sides of the monitor. Also, be certain that you do not press hard on the LCD or PLASMA screen. You can permanently damage an LCD or PLASMA screen by pressing on it too hard.
If there is just dust on your screen, there is no need to fully clean it. To remove dust all that must be done is to wipe it away with a microfiber cloth. Simply wipe your screen from end to end gently with the cloth. For smoke filled room, It would be good to clean it once a month when the smoke is not around during cleaning.
Posted on Apr 14, 2009
My lawnmower is fuming when i start it. what is causing it?
Is the air filter clean? Dirty air filter creates a vacuum sucking too much gas.
Is the choke not working properly?
It it's black smoke it's burning too much gas.
If it's blue smoke it's oil. If it's oil smoke did you over fill when you put oil in.
Over filling the oil will cause it to smoke.
Bad piston rings will cause the oil to burn also.
Oct 09, 2014 | Garden
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
I just used the self cleaning option for the first time and the entire house filled with hazy smoke and a very strong , almost chemical odor - what is wrong?
The self cleaning setting goes to a very high temperature ,it is this high temperature that cleans the oven ,the remains that was left in the oven.during the cleaning cycle would have likely caused the hazy smoke and strong odour . Recomendation : use your vent fan , remove heavy residue from the oven before starting the cleaning cycle.
Dec 03, 2010 | Frigidaire Ovens
I used a soap/water solution to clean my plasma screen but used a regular cloth instead of microfiber and now there are horrible streaks on the tv that won't go away. Help! Is there anything I can do?
You can try to use a harsher cleaner like lysol but sometimes the streaks are permanent. The screen is glass but some tvs have a glare reduction layer that can be destroyed with harsh cleaners (like lysol). Your soap cleaning shouldn't have damaged it.. I would try just water and see if the streaks change. If they keep changing as you clean, its probably some scummy residue, but if they apprear to be permanent, then it could be damage. I always recommend the store bought plasma cleaner with the microfiber cloth, but if you smoke or have a really dirty tv, sometimes you have to cut it with lysol or something. Clean at your own risk, as anything not made to clean the tv can sometimes cause damage. I've seen paper towels scratch the glossy frames sometimes even.. good luck
Jun 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Player shuts off
the player is failing, due to contaminate on the optical pickup (if its used in a smoking home, dusty enviornment, or one with a fireplace) a cleaning disc may help. but most likely the optical block is failing, and the lowesst cost option is to replace it, as repair will cost you in excess of $150.00
Feb 08, 2010 | Panasonic DVD-S35 DVD Player
When cleaning my oven, the whole house fills with smoke.
sell cleaning on ovens just causes problems like this, it is normal. it cleans by burning everything inside at high temp. i always recommend cleaning the old fashioned way, once a year , with oven cleaner, or as req. roasting an oven itself to clean it is insane i think
Jul 23, 2009 | Ovens
Hello, I own a GE spectra xl44 self cleaning oven. recently my oven has started to smoke while cooking. I tried to use the self cleaner, however this only set off my fire alarm. I have cleaned all of the...
If you cannot get to clean it fully then open your windows, place a fan in the doorway to encourage the smoke to leave the house and put it on a cleaning cycle.
Use aluminium foil to line the base of the oven rack. That will stop this from happening again when your containers are overfilled.
Jul 23, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
