Question about Motorola Mobility RAZR V3x Cellular Phone
Help with memory card inkrazr cellphone
Cant get my memory card to work in mykrazr k1m motorola cell phone. cant figure out how to save to memory card.
    President:
  • 949 Answers
Do not use card reader and format with pc, you only format the card with the phone,and only once.
If you format the card with your pc the phone migt not see the card anymore,even if you format fat32. The card is suppose to be formatted with phone because the phone needs to build folders in the card.
As for saving anything,say pic,just open options and choose card.
Posted on Apr 14, 2009
  • odiebugs
    odiebugs Apr 27, 2009
    Yes, you can use a card reader to look and place and remove stuff
    from the card, you just do not want to format a card with a computer.
    Registry,where do you get this from,the phone runs firmware, a registry is what windows uses,when a phone format's card it build files
    and they are not listed in a registry because the phone does not have one.
    President:
  • 762 Answers
Hi, before you use a memory card it has to be formated. Use card reader and format FAT32 ( or FAT) and also check the size. V3 support only 1GB and with some firmware 2GB only.
Rate me if it helped. Thanks.
  • 270rexton
    270rexton Apr 22, 2009
    hello there, just wanna rctify : it doesn't matter if you using card reader(pc) or not. Upon insertion in to the phone it create registry itself.If there's an issue phone will as to format it anyway. Recommending FAT as other formats could rise issues depending on pc's OS.
Motorola krzr k1m + 2gb memory - won't read the card
for your added information, it is by chance that the 2 gb sd card can be recognize by your phone. normally, krzr 1 doesn't support 2 gb. you may think that others do have. it all depends on the firmware they have and sometimes on the brand of the sd card like micromax
it is really by chance that it will be recognize. most of the time, it can be hardly recognize.
take care.
Feb 07, 2010 | Motorola Mobility KRZR K1m Cellular Phone
Naghahang ung cellphone ko! letse!
speaking taglog sir? anyway try to remove the memory card first and try to open it again. if still not working then try to reformat your phone.
Nov 04, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
Razr K1m with Memory Card = No service
It is very possible that the card is bad. The phone is rated for a 4 gb card. You might want to try a Sandisk microsd instead. If it still doesn't work it may actually be the phone. Sorry I wasn't much help..:-(
Jun 03, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Memory card placement??
the memory chip sits right on top the label should face up.
May 13, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Cant figure out how to put music on sd for motorola krazor k1m
make sure you are using phone and card memory. factory defaults are just phone memory.
same as phone and sim card contacts. it will use one or both.
Feb 26, 2009 | SanDisk 2GB microSD Memory Card
I have a Motorola KRZR k1m - I have a sd card in it with my songs loaded on it and have always been able to play my music with the mp3 player on it, suddenly the mp3 player quit working what could be...
The program could have been corrupt due to an immense amount of scripts that were written when each song played. What you might need to do is do a soft reset on your phone. Take the card out of the phone and take the battery out for about a minute. Place it back in and try to start the player. If the player doesnt start then put the memory card in then try to start it.
The last resort would be to erase everything on the phone so that everything goes back to manufacturers settings, the player would work then but you would need to save your phone numbers, and pictures, and videos, before doing that because everything will be erased.
Dec 10, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Saving text messages from v365
You can save the text messages into the computer using the software from Motorola.
Motorola Phone Tools allow you to transfer all the information between the cellphone and the computer.
You can get it from store.motorola.com
Also remmber that you are not gonna be able to save text messages or contacts information in a memory card.
The memory card allow you to transfer just Multimedia stuff as music pictures or videos.
Good luck
Oct 24, 2008 | Motorola Mobility V365 Cellular Phone
Phone have i test screen blue screen
Charge, leave it alone for a week...then turn it on and try to save all you can to a memory card. My phone still does this 2 years after first trouble.
Aug 20, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Motokrzr k1m
The K1M only takes a Transflash card. Remove the battery cover, and at the bottom, you will see a small rubber cover. Pry it out with a fingernail, and insert the Transflash card to to the left. Replace the rubber cover and the battery cover.
Dec 13, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3x Cellular Phone Logo
161 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
