Question about Uniden BC60XLT Handheld Scanner
Cant find user manual for it.
I have a uniden bc 70xlt scanner but I cant find a user manual for it anywhere. I can program the 20 channels ok but I dont know about the "pri", "srch", "limit", or "dly" buttons. I push them and either nothing happens or I get an error message.
  • 211 Answers
Pri is priority. On older Bearcat scanners, channel 1 is priority. When this is turned on, the scanner will automatically switch to channel 1 if there is a transmission on that channel.
Srch is search. It will enable you to check all frequencies in a certain, user definable range. Let's say you want to check every frequency between 154.000 and 155.000 for traffic. You would type the following sequence.
154.000
limit
155.000
limit
search
If you have a "hold" button, that will allow you to stay on a frequency while searching after the transmission has stopped.
Dly is delay. This will add a 2 second delay to the end of a transmission before scanning or searching resumes. This prevents the scanner from missing a reply to a transmission when a conversation is taking place.
I hope this helps! Good luck!
Posted on Feb 25, 2010
    President:
  • 2,761 Answers
You can download and print the full manual here:
http://uniden.com/pdf/BC60XLTom.pdf
Bill B.
Posted on May 21, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Jan 02, 2010
    I couldn't find a free manual for your 80s vintage scanner, but if you feel the need to spend $10 you can purchase one here:
    http://www.vintagemanuals.com/manual.php...
    It sounds like you've got the programming figured out, so here's a brief description of the keys that you mentioned.
    PRI is short for priority. You can designate a priority channel by pressing the PRI key while the scanner is stopped on the channel. Doing so will cause frequent sampling of that channel while in scan mode. All in all, not much more than an irritant on a 20-channel scanner.
    SRCH lets you search through a designated range of frequencies so that you can identify and later proghram active frequencies.
    LIMIT is a search function that is used to set the frequency range to be searched.
    DELAY holds the frequency on frequency for about 2 seconds after a transmission ends. It's handy for catching responses, and can be used in both SEARCH and SCAN modes.I have it set on all channels of all of my scanners.
    Here is a link to the manual for the BC245XLT. It has a lot of features that your oldie doesn't offer (more channels, trunked systems monitor, etc.) but the keyboard is similar to yours, and the SEARCH instructions will work for your scanner. There's more info in the manual that you can use too, so you might want to download and print the manual (it's a free download).
    http://www.uniden.com/pdf/BC245XLTom_VA....
    And finally, for a comprehensive database of active frequencies in your area, visit:
    www.RadioReference.com
I need a schematic for this scanner
This site says they have them but you have to sign up to receive the free download.
platformusers net
Oct 29, 2015 | Uniden Bearcat BC 145XL 16 Channel Scanner...
Cant get any channels to pick up
I recommend that you first scan the weather band to make sure that the scanner is working properly. You should be able to pick up one of the NOAA broadcast frequencies just about anywhere in the USA. No reception? Your scanner probably needs professional repair. If you receive weather broadcasts, make sure that you have active frequencies for your area programmed into the scanner. You can find a comprehensive database of active frequencies, and a lot of other useful scanning information by visiting:
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC95XLTom.pdf
Bill B.
Listening in since the 60's
Dec 15, 2010 | Uniden BC-95 XLT Scanner
Programing a bc 350 scanner
The best programming instructions are in the scanner operating manual. You can download and print it here:
For the BC350A:
http://www.uniden.com/pdf/BC350Aom.pdf
For the BC350C:
http://www.uniden.com/pdf/BC350Com.pdf
Bill B
Jun 18, 2010 | Uniden BC350 Base Scanner
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
I need to buy a user manual for a bc147xlt scanner
You can download from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/UNIDEN/BC%20248CLT-_E
Thanks.
Aug 30, 2009 | Uniden BC248CLT Base Scanner
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
BEARCAT BC 175 XL--Where might I download manual? Thanks
hi . i w given a Uniden Bearcat 175XL 16 channel scanning radio. the OPERATION buttons are: PRI SPEED WX LIMIT SRCH HOLD DELAY LOCKOUT and in orage color: SCAN MANUAL. please help. the only thing i can get to hear is the WEATHER CHANNEL. i cant even hear the squelch. can u help
Mar 21, 2009 | Uniden BC340CRS Base Scanner
Programming a scanner
To program a BC 70XLT turn the scanner on and hit the man key.
enter the channel you want to program (ie 1) hit the man key again then enter the frequency you want to scan (IE 450.625) then hit the E key to enter the freq into the location if you want to sequence to the next channel then hit the man key again enter the freq and hit the E key.you can go through all 20 channels this way.
Sep 12, 2008 | Uniden BC60XLT Handheld Scanner
Uniden/bearcat BC-100
If it's indeed a BC-100 and not a BC-100xlt, the 16 channels are easy to program and use.
1. Press MANUAL 3 MANUAL with 3 being the number of the channel you wish to program.
2. Enter the frequency for that channel (e.g., 162.55) followed by ENTER.
3. Follow the same sequence for each channel you wish to program, except that pressing MANUAL after you program a channel will advance the scanner to the next channel.
To scan, simply press the SCAN button after your frequencies are programmed.
Bill B.
San Antonio
Jul 15, 2008 | Uniden BC248CLT Base Scanner
How to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
May 31, 2008 | Health & Beauty
Uniden BC60XLT Handheld Scanner Logo
275 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
