Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Blower Pully slides off shaft.
I have a master cool evap. After 10 days or so, the pully slides off the end of the shaft. It seems aleigned and works fine for a while. Maybe I am not tightening the set screw with the alan wrench enough but am afraid to tighten too much. Thanks, Tom White
  • tomcharwhite Apr 14, 2009
    Thanks, I will!
  • Azstu Mar 05, 2012
    Hey Tom. Did you ever resolve this ( I know its 3 yrs later ;)./ I have same issue. pulley slides off.. and have tightened setscrew.. but thinking something else is needed.. Anyway if you have any info on how you fixed this. or links to a diagram or two. that would be cool ( pun intended )..stu
    Scholar:
  • 144 Answers
Tighten away.
Posted on Apr 14, 2009
Getting crank pully off
YOU MAY NEED A PULLING TOOL MACHINE MART SELL THESE FOR ABAUT 15£ A CRADLE HOLDS LEGGED CLAWS THAT SLIDE BEHIND PULLY THEN A CENTRE BOLT IS USED TO JACK OFFTHE PULLY THIS WILL BE ON A TAPERD SHAFT SO IT WILL COME OFF WITH A BANG, THE PULLY IS CAST IRON SO IT WILL TAKE A FAIR BIT OF STICK GOOD LUCK AND BE CAREFUL
Aug 07, 2011 | Car Audio & Video
How do i time my Golf 1 correctly? it consumes a lot
its tricky enough if your not sure what your doing but ill run you through it. 1. remove top rocker cover and timing belt cover. 2 make up the position of the pully on the cam shaft at the top and the drive shaft at the bottom, this marks are you fail safe incase you cant time the engine. 3 remove the timing belt and pully tentioner, note if your going this far you are as well to replace the timing belt,tentioner and water pump. 4 On the cam shaft at the top if you force them to turn you will see a small indicator mark on the shaft this mark has to line up with the other indicator mark on the housing between the cam shaft and the cam shaft pully, once they line up your top end is timed, mark up the pully incase it moves. 5 on the drive shaft pully there is also markings that have to line up but you can also feel the position of the pully as you turn it, you will feel the piston been forced up and it is timed at top dead centre on cylinder one, which means the the piston has to be at the top just before the point of returning back down, using your feeling as a guide and the markings lined up you will have timing. also mark up this pully, your new marking should be very very close to the fail safe markings you put on at the start. when you have your marking replace the timing belt with the longest distance between pully contact going on first, try not disturb your timing or your hard work will have been for nothing, make sure the tentioner on the belt is tight but not to tight to the point where you ll stretch the belt or snap it, put everything back as you found it and crank the engine, job done, best of luck. hope this helps( rate me on my answer thanks )
Aug 27, 2010 | 2000 Volkswagen Golf
View of mark for timing belt.
hi from uk the cambelt/timing belt comes as a kit ie timing belt and tensioner cost £50 here in uk ? it is not too difficult diy job approx 2hours the engine must 1st be set to TDC number 1 firing then at this setting the cam cog mark is a hole drilling in the web of cog and should line up at 12 oclock upwards and using a mirror look thro drill hole and you will see a vertical notch/groove behind on font engineface this is correct mark the crank cog mark lines up with aother mark on engine front face at approx 12 30 pm oclock ? if now set you slacken tensioner bolts and push t/pully away to left from belt ? then remove belt next remove complete tensioner assy after undoing bolts then fit new tensioner push t/pully to left from belt run and lock bolt/s recheck t/marks then fit new belt from c/shaft in anticlockwise rotation when fitted release tensioner bolt and allow to tension belt push t/pully onto belt and lock up tensioner bolts20=27 Nm rotate engine manually for four turns then recheck marks ? should still aligne then re assemble torque crank bolt to =140-150 Nm A LITTLE HINT ? b4 you remove the water pump belt ? slacken thefour 10 mm headed bolts (spanner size) that secure w/pump pully to pump it will be easier to halt rotation of pully if you holt belt tight by hand this pully has to come off to remove c/belt covers same for power steer belt which is also driven from the w/pump pully the power steer pump slide adjuster has a 12 mm bolt you slacken and best done with open end spanner ? after slackening the pump mounting bolts/nuts underneath pump hope you can follow this info/tips wish you good luck from uk
Apr 09, 2010 | 2000 Hyundai Accent
How do i repair the gasket behind the crank shaft seal?I have a major oil leak and i was told my gasket behind the crank shaft in the front needs to be changed. I have nearly no experience on vehicles so...
Front crank seal. First you have to have room to work, so this may require you remove the radiator and some plastics. Remove the serpentine belt,remove the bolt in the center of the crank pully. The pully should slide off with some resistance but not enough to need a puller. Once the pully is off, there's your sea. Pop the seal out with a screwdriver. Clean the surface of the hole where the seal was, Put some sealer,on the outer perimeter of the new seal and some grease on the seal lips. Evenly tap the new seal into place with the spring side of the seal facing in. make sure seal is at the point the old seal was. Now take the pully and clean the surface the seal rides on, very clean and nd coat with a thin coating of grease. Slide the pully back on and secure with bolt. Then belt, then radiator. Any trouble, holler. Good Luck, Ned
Oct 17, 2009 | 1994 Dodge Caravan
2000 Suzuki ATV Pully assembly problem
HELLO; Go on line and you can get a manual off of e-bay or google. The weights your talking about are the counter weights for one half of the drive belt sheive. GOOD LUCK.....GREASY
Aug 07, 2009 | Sport & Outdoor - Others
Popping noise, like pop corn
you may want to open up the blower wheel housing in the front part of the unit there may be an obstruction in there or a loose blower wheel .Try to move the blower wheel by hand and see if it is loose.If that does not work you may have an object in the inner drum fins or the three tumblers in the the drum.To remove them you need to lift the top and use a 5/16 nut driver .Hope i fixya :)
May 18, 2009 | Dryers
WE HAVE A KITCHENAID MODEL NUMBER YKEYS700GQ0 WE BOUGHT BRAND NEW AND EVERYTHING WORKS LIKE, THE BLOWER AND HEATER BUT THE TUB WILL NOT TURN. ALL THE CONTROLS ALSO APPEAR TO BE WORKING FINE. ALSO WHAT...
That is your idler pulley which holds the tension of the belt to the motor.If you have a access panel in the back of dryer than that would be the place to install the pulley.
May 23, 2008 | KitchenAid Dryers
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
114 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
