Question about Sanyo PLC XU35 Multimedia Projector
Projector Multimedia pro X
The projector turns on but does not show any further activity. I also need an operational manual and possibly other troubleshooting info.I am new at this but would like to fix the projector which I recently got on the cheap from ebay.
  • faralight Feb 27, 2008
    sanyo XU10B.i've got the same problem.and all cables connected well.the pj turns on but doesnt react to any operation.i can only turn it on or off.
Hav you checked to seeall the connections are correct
Posted on Oct 22, 2007
6ya staff
SOURCE:
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
Cooling fan for lamp does not activate.
This is a very serious problem, and needs to be addressed by a service professional. If the fan does not operate it will allow the heat from the bulb to be trapped inside the projector. Often times this can result in catastrophic bulb failure (i.e possible explosion).
I was in a church where this was allowed to happen on a projector that was suspended from the ceiling and shards of glass reined down onto the chairs below and melted through the fabric.
Please see a local service professional or look up an authorized service pro using your zipcode here:
http://www.mitsubishi-presentations.com/customercare/servicesearch.html
Mar 05, 2011 | Mitsubishi LVP-X80U Multimedia Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Apple Driver for Model l713v
it may not be the operating system as much as the computer. the native resolution for the projector is 800x600, but the max is 1024x768 and it's analog. so, you may have to change your resolution.
Jan 16, 2008 | Luxeon L713V Multimedia Projector
Projector and pc not picking each other up
Hi, Normally your connection should work straight out. Pls verify that your dvi output is enabled/activated by checking your display properties. In a Windows based OS machine, right click on any clear area of your desktop, click on Properties. Click on the settings tab, Advanced button. Check on the different abs such as Monitor, display and others. There should be an indicator for dual view or enabling/activating your secondary display unit (which is your projector). Hope this be of some idea/help. Post back how things turn up or should you need further information. It may also be of help if you can provide info on your PC. Good luck and kind regards.
Sep 23, 2007 | LG DLP Projector 1400Lum RD-JT30...
Sanyo PLC XU35 Multimedia Projector Logo
210 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
