Question about Pioneer Audio Players & Recorders
Dirty right channel
2 sets of o/p. Changed all. Bias to right side o/p's not seady at .7v and bias comes from IC102. Without schematic, cannot trace back further. Help..!
  • 4,234 Answers
It would help to know the model number. Also, hte bias should be .6 not .7V. What is IC102?
Thanks,
Dan
Posted on Apr 14, 2009
Distorted sound / fuse blows off when changing amp class.
The class A switch adjusts, via an optocoupler, the bias on the output transistors.
I would check the standard bias and class A bias adjustments.
Mar 22, 2014 | Marantz PM7200 2-Channel Amplifier
I have a behringer 2500. both channels are distorted but not out. what would need to be replaced.
It seems to me that you have a bad transistor, T14 or T13 to be precise. T14 most certainly is in short circuit or its companion T13 (T14 is a small signal NPN transistor whereas T13 is a small signal PNP transistor). I just fixed one with the same symptoms as yours. You should be able to measure T14 collector voltage against ground (metal chassis) and the reading must be very close to +15VDC. Also, measure T14 emitter voltage to ground and the reading must be very close to -15VDC. If any of those voltages is compromised, you will not be powering the amplifier's operational amplifiers (U4, U5, U6) right. Check T14 and T13 with your multimeter and replace them as needed. Also, keep in mind that after replacing any of those transistors you will be required to readjust the BIAS current for your amplifier's drivers, which by the way, is a very easy task to accomplish. You know your BIAS current is misadjusted when your output transistors get really hot even under no signal conditions or when your amplifier distorts at very low volume levels or on high frequencies amplifying. To adjust the BIAS current for channel 1's driver transistors, wait until the amplifier has cooled down, locate and adjust VR3 until you read 80 mV across R2. To adjust BIAS current for channel 2's driver transistors, locate VR6 and adjust it until you read 80mV across R106. You need to wait until the amplifier cools down to set BIAS current right, If the output transistors' heat sinks get hot before reaching proper BIAS current adjustments, wait until they cool down to average room temperature and retake BIAS current adjustment. Once both channels BIAS currents have been readjusted, apply a thin coat of thick nail polish to the sides of VR3 and VR6 to keep vibration from misadjusting BIAS currents again... T14 goes down under severe BIAS currents shifting and it just makes me wonder as to why BEHRINGER does not apply a setting substance to VR3 and VR6 so they do not shift under sever vibration conditions, after all, almost any major amplifier manufacturer in the world does it. Good luck!
Nov 10, 2012 | Behringer EUROPOWER EP2500 Amplifier
I need to find the proper settings for driver &final bias for a washington 8719 cb.
I assume someone has changed the finals or was trying to get more power and adjusted something they shoudln't have?
Without the proper equipment it is not possible to bias the final stage properly. Take it to someone who has a service monitor and the manual.
Oct 08, 2009 | Uniden Radio Communications
I have a luxman m-117 the left channel stops working
Hiya, the first thing that comes to mind for me is the bias setting is incorrect. This is a common mod done by many people that often leads to bad things! The good thing is that it does sound likely as everything is OK at this point (hopefully).
I suggest it goes in to be checked and get someone who knows amps to set the bias correctly. I would advise you try (unless you have a bit of experience with meters etc) as things can go bang.
The bias setting for the amp are 0.5mv between TP1/TP2 and same on other channel TP3/tP4
Hope that helps
Jul 25, 2009 | Audio Players & Recorders
Amp : sansui au11000 blown transistors on driver board
may i ask you did you put silicone grease in your transistor and apply a good mica insulator in all of your transistor---------look for any burnt resistor or explosive capacitor -----check for scew tie your supply voltage to earth by wrong.
Aug 03, 2008 | NAD C320 2-Channel Amplifier
DENON PMA520 Amp. Suspect left channel not working as set bias to all left and get nothing out of left speaker. Right speaker working. Tried interchanging speaker connections and get same result from...
you have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Jul 27, 2008 | Denon Audio Players & Recorders
Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
May 02, 2008 | Sony CCP1300 Monaural 1-to-3 16x Master...
Recording problem onkya model ta2090
check electrolytic caps about the dolby chip. have seen caps (maybe 100uf) go dry and produce problems like this
Oct 31, 2007 | Onkyo TA RW544 Single Dual Cassette Deck
TV losing its channel memory
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
Jun 16, 2007 | Acer AL2671W 26 in. LCD Television
53 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
