Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H Logo
A
Anonymous Posted on Sep 04, 2013
Rinnai r42 - Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H
2answers
Rinnai r85 not firing up (but I have power to the controller) with no error codes
I could not find r85 model on rinnai website. There is a troubleshooting guide on rinnai website. 100000652-Troubleshooting TWH Diagnostic Codes.pdf (rinnai.us) It may help to find a solution.
Our hot water will stop coming through the tap until we reset it on the rinnai wall control and then it works again?
trouble shooting section will help https://sahotwater.com.au/specifications/Rinnai/Service%20manual/smV1616W_V2018W_V2020W.pdf
1helpful
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Rinnai 2532 error code 10
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
My Rinnai infinity 20 water heating is not lighting
Just joined fixya and am a Rinnai service manager in Australia. Is this still an issue?
Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
3helpful
Dip switch settings for Rinnai V1200 & V1500
curios to find out if you had any help on this subjuct at all?
I nee the manaul for rinnai 26 solar
you can go to the rinnai web site and down load this,, they are available on line,,
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
