Question about Trekstor i.Beat mood MP3 Player
Not able to use it crashed
Am not able to switch on it or connect it to the computer it says i/o device error i changed the battreies it is not not working still it is a i beat mood fm mp3 player it does not have reset button plz help me
  • Anonymous May 19, 2008
    Trekstor i.beat mood have an error I/O can you help to this problem?
    New Friend:
Hi! I wrote to the support center for a similar problem. They sent me the solution which has worked successfully! Hope it helps you out too. Their solution -->
"Thank you for requesting information from your TrekStor Service Team.
The reason for the described malfunction may be a damaged firmware. We recommend to reinstall the current firmware on your i.Beat mood. You can download the firmware for the i.Beat mood from our web sites at http://www.TrekStor.de/en/index.php. Choose "Service" and then your MP3 player.
Please note that the firmware can only be reinstalled using a Windows operating system. The files which are downloadable on our web sites are packed and in ZIP format. You will need archive software as e.g WinZIP to open and extract this file. If you do not have a suitable programme installed on your computer you can download it as shareware from the internet.
Install the downloaded firmware on your PC by double-clicking the file "Setup.exe". Start the firmware update tool afterwards. Remove the battery of the i.Beat mood. Press the MP3 player's Play button for approximately five seconds. Now connect your i.Beat mood with still pressed Play button to your computer. Keep this button pressed until Windows detects a new device in recovery mode.
After your computer has installed the i.Beat mood the firmware update tool will detect your MP3 player. Now you will see the recent (current) and the new (update) firmware version. If "Format Data Area" contains a checkmark the i.Beat mood will be formatted before the update and all data stored on it will be deleted. TrekStor advises to format the i.Beat mood along with every firmware update.
http://www.fixya.com/support/t198710-not_able_use_crashed
Afterwards, your i.Beat mood can be handled as usual. Moreover the MP3 player should be accessible again under My Computer.
We know that you as a customer have the choice and we thank you for having decided for TrekStor."
Posted on May 15, 2010
Posted on May 19, 2008
Posted on Feb 19, 2008
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: not able to use it crashed
if you still have a warranty, you can send it in for repair. I had the same problem and used the extended warranty to have it repaired. or you can go to the website and download the updated firmware to try and solve the problem. Hopefully the operating system doesn't have to be replaced.
Posted on Apr 18, 2009
I have Model 1058 Mouse bought 12/09. Computer crashed (motherboard) and had to get new one. Can't find installation disk for mouse. Can you help?
change the mouse battery and there is a button named connect on mouse keep pressing the connect button for 3-4 minuts and keep mouse near wireless device which is connected to the computer in USB port then restart your computer and mouse will work fine.
Mar 30, 2010 | Microsoft Wireless Laser Desktop 4000...
Will not reboot
did u by chance change any settings in the bios.... if yes please change the settings.... if u donno hw to chnge the bios settings... please ask me...
Jun 07, 2008 | Compaq Presario 5000 PC Desktop
Tip
10 Reasons Why Personal Computers That You Must Know
10 REASONS WHY PC's CRASH
1. VIRUSES
The first sign of virus infection is instability. Some viruses erase the boot sector of a hard drive making it impossible to start. This why it is a good idea to create Windows start-up disk.
Go to Start Menu-Control Panel-Add/Remove Programs and look for the start up disk tab.
Virus protection requires constant vigilance. A virus scanner requires a list of viurs signatures in order to be able to identify viruses. The signatures are stored in a DAT file. DAT files should be updated weekly or monthly from website of your antivirus software.
2. SOFTWARE
A common cause of computer crash is faulty or badly installed software . Often the problem can be cure uninstalling the software and then reinstalling it.
Another is uninstall some programs that have file sharing components to other programs like operating system that will make your computer unbootable.
If your Windows problem crash, try entering to Safe mode. This can be done during start up and when you see the message "starting windows" press F4 and it will take you to safe mode.
Safe Mode loads a minimum of drivers. It allows you to find and fix problems that prevent Windows from loading properly.
3. PRINTERS
The action of sending a document to print creates a bigger file often called a postcript file.
Printers have only small amount of memory called a buffer. This can be easily overloaded. Printing a document also uses a considerable amount of CPU power that will slow down your computer's performance.
If printer is trying to print unusual characters, these might not be recognised and can crash the computer. Sometimes printers will not recover from a crash due to confusion in the buffer.
A good way to clear the buffer is to unplug the printer for 10 seconds. Booting up from a powerless state called a cold boot and it will restore your printer's default setting.
4. HARD DISK DRIVES
The information on a hard starts to become piecemeal or fragmented. It is good to defragment the hard disk every week or month to prevent a screen freeze.
Go to Start Menu-Accessories-System tools-Disk Fragmenter
Hard disk will slow down and crash if they are too full. Do some housekeeping on your hard drive every few months and free some space on it. Open the Windows folder on C drive and find the temporary internet file folder. Delete the contents that can free a lot of space.
Empty the recycle bin every week to free some space. Hard disk drives should be scanned every week for errors or bad sectors.
Go to Start menu-Programs-Accessories-System Tools-Scan Disk
5. HARDWARE CONFLICT
The number on reason why Windows crashes is hardware conflict. Each hardware device communicates to other devices through an interrupt request channel (IRQ). These are supported to be unique for each device.
For example, a printer usually connects internally on IRQ7 and keyboard usually uses IRQ1. Each device will try to hog a single IRQ for itself.
If there are lots of devices, or if they are not installed properly, two of them may end up sharing the same IRQ number. When the user tries to use both devices at the same time, a crash can happen. The way to check if your computer has a hardware conflict is checking to the Device Manager.
Go to Start menu-Control Panel-System-Hardware-Device Manager
Often if a device has a problem yellow ' ! ' apears next to its description in the device manager.
The best way to fix this problem is to remove the problem device and reinstall it again. Sometimes you may have to find more recent drivers on the internet to make the device function properly. A good source is www. driverguide.com.
6. BAD RAM
RAM (random access memory) problems might bring on the screen of death with a message saying Fatal Exception Error. A fatal error indicates a serious hardware problem. Sometimes it may mean a part is damaged and need replacement.
But fatal error cause by RAM might cause by mismatch of chips. For example, mixing 70ns (nanosecond) RAM with 60ns will usually force the computer to run all the RAM at sloer speed. This will often crash the machine if the RAM is overworked.
One way to solve this problem is to enter to BIOS setting and increase the wait state of the RAM. This can make it more stable. Another way to troubleshoot is is to rearrange the RAM Chips on motherboard, or take some of them out. Then try to repeat the circumstances that caused the crash. When handling RAM try not to touch the gold connections as they can easily damage.
Parity error messages also refer to RAM. Modern chips are either parity (ECC) or non parity (Non-ECC). It is best not to mix the two types as this can cause trouble.
EMM386 error messages refer to memory problems but not connected to bad ram. This may be due to free memory often linked to old DOS based programs.
7. BIOS settings
Every motherboard is supplied with range of chipset settings that are decided in the factory. A common way to access these settings is to press F2 or delete button during the first few seconds on a boot up.
Once inside the BIOS, great care should be taken. It is a good idea to write down on a piece of paper all the settings that appear on the screen so that you can revert the setting if you change it and computer becomes more unstable.
A common BIOS error concerns the CAS latency. This refers to the RAM. Older EDO (extended data out) RAM has a CAS latency of 3. Newer SDRAM has a CAS latency of 2. Setting the wrong figure can cause the RAM to lock up and freeze the computer's display.
Microsoft Windows is better at allocating IRQ numbers than any BIOS. If possible set the IRQ numbers to Auto in the BIOS. This will allow the windows to allocate the IRQ numbers ( make sure the BIOS setting for the Plug and Play OS is switched to 'yes" to allow Windows to do this).
8. FATAL OE EXCEPTIONS and VXD ERRORS
Fatal OE exceptions errors and VXD errors are often caused by video card problems. These can be resolved easily by reducing the resolution of the video display.
Go to Start menu-Setting-Control Panel-Display-Settings
Here you should slide the screen area bar to the left. Take a look at the colour setting on the left of that Window. For most desktops, high colour 16-bit depth is adequate.
If the screen freezes or you experience system lockups, it might due to video card. Make sure it does not have a hardware conflict.
Go to Start Menu- Setting-Control Panel-System-Device Manager
Here select the + beside Display adapter. A line of text describing your video card should appear.
Select by making it blue and press the properties-Resouces and select each line in the Windoe. Look for a message that says No Conflicts.
If you have video card hardware conflict, you will see it here. Be careful at this point and make note of everything you do in case you make things worse.
The best way to resolve hardware conflicts is to uncheck the Use Automatic Setting box and hit the change setting button. You are searching for a setting that will display no conflicts message.
Another useful way to resolve video problems is to
Go to Start Menu-Setting-Control Panel-System-Performance-Graphics
Here you should move the hardware acceleration slider to the left. As ever, the most common cause of the problems relating to graphics cards is old or faulty drivers ( a driver is a small piece of software used by computer to communicate with a device)
Look up your video card's manufacturer on the internet and seach for the most recent drivers for it.
9. OVERHEATING
CPU (central processing units) are usually equipped with fans to keep them cool. If the fan fails or if the CPU gets old it may start to overheat and generate a particular kind of error called kernel error. This common problem in chips that have been overclocked to operate highspeeds that they are supposed to.
One remedy is to get bigger fan and install it on the top of the cpu. Some special cooling fans / heat sinks are available also.
10. POWER SUPPLY PROBLEMS
With all the new construction goind on around the world, the steady supply of electricity has become disrupted. A power surge or spike can crash a computer as easily as a power cut.
The solution is to use UPS (uninterrupted power supply) to give you clean power when there is electricity and will give you a few minutes to perform a controlled shutdown in case of a power cut.
on Dec 18, 2010 | Computers & Internet
Tip
Things You Must Know To Avoid PC Crash Part 1
Fatal error: the system has become unstable or is busy," it says. "Enter to return to Windows or press Control-Alt-Delete to restart your computer. If you do this you will lose any unsaved information in all open applications."
You have just been struck by the Blue Screen of Death. Anyone who uses Mcft Windows will be familiar with this. What can you do? More importantly, how can you prevent it happening?
1 Hardware conflict
The number one reason why Windows crashes is hardware conflict. Each hardware device communicates to other devices through an interrupt request channel (IRQ). These are supposed to be unique for each device.
For example, a printer usually connects internally on IRQ 7. The keyboard usually uses IRQ 1 and the floppy disk drive IRQ 6. Each device will try to hog a single IRQ for itself.
If there are a lot of devices, or if they are not installed properly, two of them may end up sharing the same IRQ number. When the user tries to use both devices at the same time, a crash can happen. The way to check if your computer has a hardware conflict is through the following route:
* Start-Settings-Control Panel-System-Device Manager.
Often if a device has a problem a yellow '!' appears next to its description in the Device Manager. Highlight Computer (in the Device Manager) and press Properties to see the IRQ numbers used by your computer. If the IRQ number appears twice, two devices may be using it.
Sometimes a device might share an IRQ with something described as 'IRQ holder for PCI steering'. This can be ignored. The best way to fix this problem is to remove the problem device and reinstall it.
Sometimes you may have to find more recent drivers on the internet to make the device function properly. A good resource is www.driverguide.com. If the device is a soundcard, or a modem, it can often be fixed by moving it to a different slot on the motherboard (be careful about opening your computer, as you may void the warranty).
When working inside a computer you should switch it off, unplug the mains lead and touch an unpainted metal surface to discharge any static electricity.
To be fair to Mcft, the problem with IRQ numbers is not of its making. It is a legacy problem going back to the first PC designs using the IBM 8086 chip. Initially there were only eight IRQs. Today there are 16 IRQs in a PC. It is easy to run out of them. There are plans to increase the number of IRQs in future designs.
2 Bad Ram
Ram (random-access memory) problems might bring on the blue screen of death with a message saying Fatal Exception Error. A fatal error indicates a serious hardware problem. Sometimes it may mean a part is damaged and will need replacing.
But a fatal error caused by Ram might be caused by a mismatch of chips. For example, mixing 70-nanosecond (70ns) Ram with 60ns Ram will usually force the computer to run all the Ram at the slower speed. This will often crash the machine if the Ram is overworked.
One way around this problem is to enter the BIOS settings and increase the wait state of the Ram. This can make it more stable. Another way to troubleshoot a suspected Ram problem is to rearrange the Ram chips on the motherboard, or take some of them out. Then try to repeat the circumstances that caused the crash. When handling Ram try not to touch the gold connections, as they can be easily damaged.
Parity error messages also refer to Ram. Modern Ram chips are either parity (ECC) or non parity (non-ECC). It is best not to mix the two types, as this can be a cause of trouble.
EMM386 error messages refer to memory problems but may not be connected to bad Ram. This may be due to free memory problems often linked to old Dos-based programmes.
3 BIOS settings
Every motherboard is supplied with a range of chipset settings that are decided in the factory. A common way to access these settings is to press the F2 or delete button during the first few seconds of a boot-up.
Once inside the BIOS, great care should be taken. It is a good idea to write down on a piece of paper all the settings that appear on the screen. That way, if you change something and the computer becomes more unstable, you will know what settings to revert to.
A common BIOS error concerns the CAS latency. This refers to the Ram. Older EDO (extended data out) Ram has a CAS latency of 3. Newer SDRam has a CAS latency of 2. Setting the wrong figure can cause the Ram to lock up and freeze the computer's display.
Mcft Windows is better at allocating IRQ numbers than any BIOS. If possible set the IRQ numbers to Auto in the BIOS. This will allow Windows to allocate the IRQ numbers (make sure the BIOS setting for Plug and Play OS is switched to 'yes' to allow Windows to do this.).
on Feb 02, 2010 | Computers & Internet
Windows Vista crashes when I connect my Linksys wusb54g wireless adapter. It worked fine for about 3 months, then started crashing, now I can't have it connected, or it crashes instantly.
This is a software conflict of the linksys device to your system, so to correct this remove first the software from your computer and then after that restart the computer and then connect the adapter on different usb port , if still having the same problem i will suggest that you have the device replace.....
Oct 09, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Apr 18, 2009 | Trekstor i.Beat move MP3 Player
New Vista PC crashes to blue screen when Mac laptop connected
well you blue screen is called the blue screen of death in the computer world it is like the red ring of death for the xbox which usually means that there is a system error or software error im not sure what it could be right now but if youll hang in there for a day ill have an answer for you
Jan 14, 2009 | HP Pavilion Slimline s3400t, Intel Core 2...
Olympus digital voice recorder VN-1000PC malfunction
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 25, 2008 | Olympus VN-1000 Digital Voice Recorder
Acer Desktop crashing
This could be an operating system fault ( Windows/Linux ) But more likely a Hardware or external connected device error.
Solution 1:) try re-installing Windows.
Solution 2:) remove any external add ons, printer/USB devices et,c. And run the computer without Them.
If the computer runs without error, you can pinpoint a faulty external or addon device.
Mike @ Compurepair.
Jun 11, 2008 | Acer Aspireā„¢ T180 PC Desktop
INOVIX IMP-1112 MP3 crashing my computer.
sounds like bad news - if the flash (update to firmware) failed during update, the item is more than likely dead. Warranty return possible? Can you try another usb device on that same pc? just to verify the usb ports are working properly and supplying proper power to the devices.
Aug 26, 2007 | Inovix iMP-20 MP3 Player
Trekstor i.Beat mood MP3 Player Logo
572 people viewed this question
Top Trekstor Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Trekstor Audio Player and Recorder Expert? Answer questions, earn points and help others
