Question about Dell 1710n Laser Printer
Paper jam / Dell 1710n
Just recently our printer has been jamming. Approximately 1/2-3/4 of a page is printed before it jams. I've opened the back panel while printing when this happens and still can't see why it stops. The paper comes about 2" before it just stops. The "replace toner/drum light" has been flashing lately and we've done that but the situation hasn't changed. In fact the light still flashes if that means anything.
  • 1 more comment
  • Murad Yousef Dec 08, 2007
    Will so far its a similer problem, which the paper is printing but it will not come out fully and its jam part from that its a good printer.
  • Anonymous Dec 18, 2007
    Paper does not draw. Load paper LED flashing with full tray
  • Anonymous Mar 17, 2014
    paper jams after replacing the toner cartridge
    Problem Solver:
  • 9 Answers
Do this You want to check the paperpath so first run a test page you will hear the paper pickup if you stick your ear to the paper tray it should pickup paper within 2 clicks any more than that that means you would need to change the bottom roller and the pad on the tray to be safe, to print a job the printer is timed to do this so if your paper is not picking up in time it will jam (also your fuser the part that heats up the toner on the paper it has a time limit to heat up if it's slow or don't heat up at all you will get a paper jam plus if that happens take your finger and run it across the paper if toner on your finger it's you fuser
Posted on Sep 13, 2007
  • David Trussler Oct 30, 2011
    This is a good tip. The pattern I am seeing is that the first print job after the printer has been idle for some time jams, but it always works on the second try. This is consistent with the fuser roller taking too long to heat up.
  • 163 Answers
Pleaz change the heater sleeve of your printer or oil it
Hp 1710n printer had a paper jam, I fixed it but it still says it has a parer jam and won't print no matter what I do.
Try unplugging the printer from the power supply WHILE IT IS SWITCHED ON. Then disconnect the data cable. Now reconnect the power cable, followed by the data cable.
This will work for several problems but is not guaranteed.
Jan 04, 2011 | Dell 1710n Laser Printer
Paper jamed and stuck inside the printer can not pull it out the back
Hi There,
Please follow the below link and download the manual in html format :
http://support.dell.com/support/edocs/systems/1710n/en/index.htm?~file=/systems/1710n/en/index.htm#online_documentation
After Downloading and opening the HTML manual , Select Troubleshooting Under CONTENTS.
After that in TROUBLESHOOTING, look for Basic Problems and look for clearing paper jams.
You have detailed description with images of how to clear the paper jams.
Thanks
Enjoy and Cheers !!!!
Please vote for me if this solution resolves your issue ......: )
Nov 02, 2010 | Dell 1710 Laser Printer
Paper jams -- about every other print, it jams
Please perform the steps mentioned in the link below:
Resolving Paper Jams
Jun 16, 2010 | Dell 1710n Laser Printer
Paer prints half the PAGER AND THEN JAMS ... I
The paper must be hitting something to cause it to jam. Take the drum/toner cart out also the paper tray. Unplug it and hold it upside down and see if something shakes out. Do not do this over carpet. If that does not do try a test page. look at the leading edge for dings and bends. If you find a bent spot on the leading edge thats where the problem is. Its almost always a small piece of paper Steven 818-888-0006
Mar 08, 2010 | Dell 1710n Laser Printer
Had a paper jam, removed paper, printer still says paper jam & won't continue
Open up the printer again and carefully check the edges of where the paper flows through the printer, its likely there's a tiny shred jamming a sensor somewhere.
Oct 12, 2009 | Dell 1710n Laser Printer
Dell 1710 paper jam
Next time don't buy Dell. That's the solution.
Oct 05, 2008 | Dell 1710n Laser Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Paper jam dell 1720dn printer
I have taken the toner and the drum out to find a paper jam and could not find anything. I even turned the printer "off" and "on" and the "paper jam" light stays on. What can we do?
Celeste
Apr 09, 2008 | Dell 1710n Laser Printer
Dell 1710n Laser Printer Logo
639 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
