Question about Dell Inspiron 1525 Notebook
I have a new key board but I don`t no how to remover the broken one its a dell inspron 1525 lap top
Do you have a pic or video on how to replace the key board on the dell inspron 1525 laptop
  • divemaster4 Apr 14, 2009
    this is just what I needed to do this thanks so much!
  • 202 Answers
The link below will take you to a step by step guide for replacing the keyboard:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/keyboard.htm#wp1180346
Good luck and please let me know how you do with the replacement.
~ Spoem
Posted on Apr 14, 2009
  • Barry Parks Apr 15, 2009
    So, if this is just what you wanted, why isn't it a FixYa?
DELL INSPIRON 1525 HELP
It should be a simple fix. Start your laptop and pay attention to the screen. Press the F12 key (or F11) to enter "SETUP" then find the NUMLOC command and make sure that its DISABLED or OFF. This will turn this option off andyou will only be able to use the number's keys on the top of the keyboard. Be careful when entering SETUP. You don't want to change anything you don't have to.
Dec 26, 2011 | Dell Inspiron 1525 Notebook
Hi All, when I am booting my laptop (Dell Inspron 1525), it is giving message that "no internal hard drive found". I restarted many times and did on-board diagonals but it now working. Can you...
Here's what I did:
  1. Start
  2. Control Panel
  3. Device Manager
  4. Expand "Network adapters"
  5. Double-click "Broadcom 802.11g Network Adapter"
  6. Click "Advanced"
  7. Select "Wake-Up Mode" from the list
  8. Change the value to "None"
you can get the help of a technician
you can get in touch with them through the website
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Sep 16, 2011 | Dell Inspiron 1525 Notebook
I have the Dell 1525. The screen is black with only the cursor appearing. Please advise
Check to see if you have the machine switched out to a stand alone monitor. This is a feature on many lap tops that lets you re-direct the signal out to a larger monitor, or if your monitor fails you can display the computer info on another screen. This feature is engaged by holding down the Fn key and tapping teither the F4, or F6 key on many lap tops. This feature can be toggled by both displaying at the same time or switched to the stand alone or the Lap top.
The other cause is that the machine has malfunctioned usually because of the CPU failure and there is nothing to boot the machine up.
Dec 30, 2010 | Dell Inspiron 1525 Notebook
I have a lapton 1440 dell inspron modl pp42L i can't fine the webcam to put in to shortcut
if have a problem dell will help you free as you have a dell you will need the model and the service tag thanks Call1-800-WWW-DELL
Oct 20, 2009 | Dell Inspiron 1525 Notebook
1440 dell inspron modl no pp42l i dont have the audio deiver can
1440 model PP42L WHILE USING SKYPE NO AUDIO ON EITHER COMPUTER
Sep 26, 2009 | Dell Inspiron 1525 Notebook
Whats wrong with my lap top cd burner it just stop workink now it says connect a burner and reastart the player
Laptop CD drives are fragile and have a rather high failure rate. The plus side is that they are cheap and easy to replace. Start your search on ebay for a new one.
As for the repair it is usually a single screw or push button to remove and install new one, that simple. Check on Youtube for your particualr model on the exact how to video :)
Sep 07, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
Broken LCD screen
Most likely, and new LCD will fix your problems. Not real expensive, and pretty easy to install.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
223 people viewed this question
Alun Cox
