Question about Pioneer Audio Players & Recorders
Dirty right channel. Changed outputs(all)and still getting dirty, Low volume on right side. Bias v. on base of o/p erratic. Base v. supplied by IC102. Wondering if this is the culprit and if so, where to buy a replacement. This is a 14 pin(pioneer)chip so good luck to me...
  • 4,234 Answers
Please post the specifics of the IC. Any markings would help.
Thanks,
Dan
Posted on Apr 14, 2009
Cx-3300 low output on low and high power
the switch for low and high power the contacts are gone or you need to check the DC voltage to the output section and the voltage drop on TX usually the likes of the cobra 148GTLDX has a bridge board you can remove and add some LCD DVM for current monitors and setting of bias etc so perhaps a regulator has failed or a resistor or the contacts on the switch you need to trace it out using current readings
Apr 21, 2014 | Connex 3300 240-Channels Base CB Radio
I have a behringer 2500. both channels are distorted but not out. what would need to be replaced.
It seems to me that you have a bad transistor, T14 or T13 to be precise. T14 most certainly is in short circuit or its companion T13 (T14 is a small signal NPN transistor whereas T13 is a small signal PNP transistor). I just fixed one with the same symptoms as yours. You should be able to measure T14 collector voltage against ground (metal chassis) and the reading must be very close to +15VDC. Also, measure T14 emitter voltage to ground and the reading must be very close to -15VDC. If any of those voltages is compromised, you will not be powering the amplifier's operational amplifiers (U4, U5, U6) right. Check T14 and T13 with your multimeter and replace them as needed. Also, keep in mind that after replacing any of those transistors you will be required to readjust the BIAS current for your amplifier's drivers, which by the way, is a very easy task to accomplish. You know your BIAS current is misadjusted when your output transistors get really hot even under no signal conditions or when your amplifier distorts at very low volume levels or on high frequencies amplifying. To adjust the BIAS current for channel 1's driver transistors, wait until the amplifier has cooled down, locate and adjust VR3 until you read 80 mV across R2. To adjust BIAS current for channel 2's driver transistors, locate VR6 and adjust it until you read 80mV across R106. You need to wait until the amplifier cools down to set BIAS current right, If the output transistors' heat sinks get hot before reaching proper BIAS current adjustments, wait until they cool down to average room temperature and retake BIAS current adjustment. Once both channels BIAS currents have been readjusted, apply a thin coat of thick nail polish to the sides of VR3 and VR6 to keep vibration from misadjusting BIAS currents again... T14 goes down under severe BIAS currents shifting and it just makes me wonder as to why BEHRINGER does not apply a setting substance to VR3 and VR6 so they do not shift under sever vibration conditions, after all, almost any major amplifier manufacturer in the world does it. Good luck!
Nov 10, 2012 | Behringer EUROPOWER EP2500 Amplifier
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
    left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
    May 06, 2012 | Behringer Music
    Denon AVR2106 One output channel shorted and blown. 2 power transistors shorted, emitter resistors and base resistors blown Have replaced all, including bias transistor I think bias is still wrong (no...
    I would also replace 2sa992 (2pcs) and 2sc1845 on preamp board- sometimes they look ok when you test them by regular meter. Check 1.2 kOm and 4.7ohm resistors at preamp pcb. Check diodes on output pcb (could be smd type, connected from base of output transistors to emitter i think)
    Sep 07, 2011 | Denon Audio Players & Recorders
    Dirty right channel
    It would help to know the model number. Also, hte bias should be .6 not .7V. What is IC102?
    Thanks,
    Dan
    Apr 13, 2009 | Pioneer Audio Players & Recorders
    2.7 misfiring
    Here are some commons causes, hope this helps.
    Air leak in the intake manifold, or in the EGR or EVAP system
    Base engine mechanical fault that affects one or more cylinders
    Erratic or interrupted CKP or CMP sensor signals
    Fuel delivery component fault that affects one or more cylinders (contaminated, dirty or sticking fuel injector)
    Ignition system problem (coil or plug) in one or more cylinders
    Vehicle driven with low fuel pressure or while very low on fuel
    The passenger side front cylinder is #1.
    Jan 28, 2009 | 1999 Dodge Intrepid
    I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
    Hi mellemcee
    Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
    regards
    Graeme
    Apr 18, 2008 | Audio Players & Recorders
    Sony TA-540E TWIN DRIVE AMPLIFIER
    Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
    regards
    Graeme
    Mar 22, 2008 | Sony TA-FE370 2-Channel Amplifier
    Channel 1 static and lack of performance
    The potentiometer (volume control) is probably dirty. Open the amp and find the "pot" connected to that volume control. You should be able to see small opennings where you can spray electrical contact cleaner inside. Give the knob a few turns and try it out. If it gets better but not perfect, repeat. If several attempts don't eleminate the problem, the pot will most likely need to be replaced. Contact cleaner can be found at any electrical supply store such as Radio Shack. Be sure to use one that says no or zero residue. I use a product called Electrosolve.
    Sep 03, 2007 | Crown CE1000 2-Channel Amplifier
    43 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    T-Comtech Repairs
    T-Comtech Repairs
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
