Question about Canon PIXMA MP130 All-In-One InkJet Printer
Ink waste i got given this i was told it would cost £80 pound to get sorted it keeps telling me the waste absorber i allmost full need help
Cool! did it! hahahahahahahaha!!!!!
Posted on Dec 24, 2007
    President:
  • 1,114 Answers
Follow this procedure... Turn on the printer press menu press scan, copy, scan to enter service mode use> to get to nvram set ABS-M level to 0 Set ABS-P level to 0 Press stop to exit..........Done Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 12, 2007
SOURCE:
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Keeps telling me ink absorber is nearly full, solution not in manual
Hi Susie,
The ink absorber is inside and does just that...absorb "waste ink". Once these fill, it is suggested to find a service center to replace it. However, you may want to consider just purchasing a new printer due to the cost of such an expense. Combine that with the cost of ink and the high consumption that most people experience with this model and it may just pay to purchase a new one.
I know that is probably not what you were expecting, but that is my best suggestion.
Thanks for using Fixya.
Jul 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer is saying waste ink absorber is allmost full/what do i do
You can reset the waste ink counter like this:
1 press menu
2 PRESS scan copy scan to enter service mode
3 use > to go to NVRAM ACCESS
4 set ABS-M LEVEL TO 0
5 Set ABS P LEVEL TO 0
6 Set press STOP to EXIT
Jun 12, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber almost full. What do I do?
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
May 04, 2009 | Canon I960 InkJet Photo Printer
Canon Pixma ip2000 saying waste ink absorber almost full
This is quoted from cannons website about your issue.
"This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
Here's the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10237&kbpage=yes
So what they are saying more or less is throw out the printer because it's going to cost more to replace the absorber than to just buy a new printer.
If you ak me it's just another way these printer companies screw customers. Just my opinion.
Sorry about the bad news but at least you have your answer.
Sean
Mar 12, 2009 | Canon PIXMA iP2000 InkJet Printer
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MP130
ink waste absorber is almost full, what should I do?
Jan 20, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Wast ink absorber is almost full
Hello Yeardy,
Take a look at this solution in :
http://www.fixya.com/support/t148101-cannon_pixma_mp150.
May that help,
Jojo
Nov 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
74 people viewed this question
Clive
Clive
old marine
old marine
Ekse
