Question about Coleman Pressure Washer PW0881800
Coleman 1600 pressure washer
The water sprays out very weakly. I bough it used. It appear to 3-4 yrs old. It wk for aboput 10 minutes. It's almost like the pump is blocking the water from getting to the sprayer?
  • 195 Answers
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Posted on Apr 14, 2009
I do not understand how to use the detergent feature
Hi Julie
There is a tube and you put that into the neat detergent. You need to fully extend it and make sure there are no kinks.
On my Coleman pressure washer you have to use a special nozzle which is black (or it might be yellow). This is a lower pressure and sprays the detergent mixed with water. Then you swap to high pressure nozzle and blast the dirt off. You will find the detergent goes down at a fast rate, 4 litres in about 15 minutes of spraying but you should only use it to spray a film of soap.
Jul 19, 2016 | Garden
Honda pressure washer manual
This is the best site to get ANY Honda manual, just send them a search request and within 2-3 hours you will hold your manual in your fingers.
Jul 28, 2012 | Cam Spray Cold Water Pressure Washer, 1600...
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
I have a coleman powermate pressure washer, model #PW0832000. It's over 10 yrs old, but brand new sitting in the box. Trouble is, I have no owner's (operator) manual. I would like to find one. Do you know...
Well, you may be out of luck with Coleman's customer service. They have gone out of business, from what I understand. I have a pressure washer just like that one. You may be able to find one on ebay, or one online that someone has scanned.
Mar 24, 2010 | Coleman Garden
I have a durabuilt DB1404 and when i'm spraying, the power washer doesn't want to keep going. It goes and stops. I tried getting the air out and that didn't work. What else could i try?
This sounds like you have an inadequate supply of water to the unit. Make sure your supply faucet is turned all the way on, use a 5/8 or 3/4" hose from the faucet to the unit, and use a smaller tip on your spray nozzle to minimize the amount of water you are using when working.
Jan 04, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
I have the Coleman powermate 2400 PSI pressure washer and on initial start it sprays and has great pressure. But once I release the spray handle it will not spray again, not even one drop of water. I have...
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Oct 22, 2009 | Coleman Garden
Coleman 1210 power washer no water comes out of gun
I've never used it before what plugs in where, the 1210 powermate, Pictures would help
Jun 01, 2009 | Coleman Pressure Washer PW0881800
Dishwasher was leaking; now gets "stuck" 3 minutes after starting
You're describing a number of issues related to old age and maintenance. First, you've likely got a mechanical timer that is getting stuck. If the price of replacement is outside your budget for an old warhorse....
Second, in come cases, the timer takes care of water level...in most, however, there is a float or aeneroid level sensor. If it is a float...it may be clogged/jammed with detergent or debris. Located in the wash tub near the front. Clean it up. If it is an aeneroid, it has a tube going from the tub to the lower part which hooks into a 3 inch or so flat sided round item with two wires coming out. With the power off, test it by blowing and sucking on the tube. Blowing into it should open the switched leads ...sucking should hold a 'vacuum'. The pressure of water opens and closes this switch to determine water level.
Jul 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Coleman Pressure Washer PW0881800 Logo
514 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
