Question about NetGear WGR614 Wireless Router
Can any 1 tell me how to install a netgear wgr614 wireless router to cable modem,, do i need an installation disk? thankyou.
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 13, 2009
Hello I have a netgear wireless router WGR614 V5 which is connected to a cable modem and since several weeks I have many unexpected and random disconnection. So I must turn off my wireless router and...
HELLO,
Why are you using two routers,these might be conflicting with each other? Somtimes the drivers need updating.Try this first,and if this fails,disconnect the cable modem and just connect the wireless router to the main phone line socket via a modem filter and connecting a wireless adapter to your pc and install the driver for this adapter.The signal from the phone socket connection to the wireless router situated close to the main phone socket.Then connect the adapter to the usb port on your PC,and let the driver software and PC do the rest.That's all I've got on my PC.
Aug 07, 2010 | NetGear WGR614 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
I had to disconnect my NetGear WGR614 Wireless Router bc it wasnt working with my cable modem and now i want to reconnect but i dont know where the instructions are? can u tell me where to find...
Did you get an install disk for your unit? Should have, if not go to the site on your wired computer and check to see if they have a printable manual for your unit.
Jan 31, 2009 | NetGear WGR614 Wireless Router
Do i need a disk to install a netgear wireless?
You need a network cable (cat5e) to connect the cable modem to the wan or Internet port on the router. Then another network cable to connect the router port(1-4) to the computer's network (NIC) port. If you are going wireless, you do not need to connect the second cable.
You do not need a disk. just power down the cable modem,router and computer.
Hook it all up, then power up the cable modem first, wait 30 seconds, then power up the router, wait 30 seconds, then power up the computer. You shold be able to get online.
Unless: you are using DSL
and unless the original owner had an encryption key on the router.
Dec 16, 2008 | NetGear DG834G Router
Lost intall disk
Well, i have set up several routers and they actually run better without the setup disk. as long as you know how to set it up, you it will work fine. (Setup disks tend to be over controlling of your network.)
To setup:
-Unplug your modem of all plugs.
-plug in your cable wire to the back of the modem.
-Plug in the ethernet wire from the modem to your router.
-Turn on the power(plug in) to your modem and give 2 mins.
Plug in ethernet cord from router to your computer.
-Plug in power to your router and give 30 seconds.
-power on your computer and give 1 min after start up.
-Make sure your internet is working and you are good 2 go.
Mar 23, 2008 | NetGear WGR614 Router
NetGear WGR614 Wireless Router Logo
62 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
