Question about Dishwashers
I have a Hobart Du 50 dishwasher and it will not fill. No power to water solenoid. The status LED flashes on the main control board which i believe the problem lies in the main board,want to ask an expert.
  • Anonymous Mar 16, 2014
    Programing control board from hl to vl on hobart dishwasher
  • 640 Answers
Are you sure this is the correct model?Are you located in the united states?I'm a hobart tech and never seen this model.I've seen a uw-50,let me know.
Posted on Apr 13, 2009
  • anthony james
    anthony james Apr 16, 2009
    did you solve your problem?
Hobart lx18h Booster does not heat up. machine powers up and will wash thouugh all cycles but the booster does not heat up water.
There are one or two hi-limit relays on the booster. One is on the front and if there is a second one, it is on the right hand side as you face the front of the unit. They are both manully have to be reset if tripped. Check them and also the booster's contacter
Oct 03, 2016 | Hobart Dishwashers
On start DW drains but does not fill...putting hot water into machine will get it to start and run cycle sometimes only...
Main control board is bad. Drain sequence is a power on test, Main board is not sending signal to open valve or is sensing water is present in the machine when it is not.
Feb 03, 2016 | Thermador DWHD651GFP Dishwasher
Where is filler sylonoid for hobart lx30h dish washer
The fill solenoid is behind the lower panel, attached to the left side of the booster tank. There is a screen in the end of the fill hose that may be clogged. You require 20 psi flow rate to run the machine properly.
Pull the top tray out, place a magnet on the door switch, with the door closed and monitor the 3 led lights on the control board while its filling. All 3 should light up. Use caution around the high voltages present on the relay board and the booster contactor.
The probes in the right rear corner of the tank send the water level signals to the control board. The tips must be clean of scale or debris that may signal that water is present, when it is not.
May 28, 2014 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Water wont come in the dishwasher. It is heating with out water and then smells like plastic burning. Hobart LX30
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Apr 18, 2011 | Hobart Dishwashers
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Hobart am 14 electric heat does not turn on water temp just drops
Assuming that the machine fill cycle works properly and the float is intact, and the heater contactor doesnt pull in:
possible heater contactor malfunction: check for power to coil
High limit snap thermostat may be tripped or damaged ( needs to be manually reset). located in heater connection cover.
Thermistor probe and or wiring to it may be damaged
main control board may not be functioning properly. check output to heater curcuit
Feb 01, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
Nov 21, 2009 | Hobart Dishwashers
Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Oct 01, 2009 | Hobart AM14-253 Free-standing Dishwasher
Hobart dishwasher am14c constant water
You have a defective inlet water fill solenoid, DO NOT TRY TO REBUILD THE OLD ONE, REPLACE THE SOLENOID. Unless you are a VERY EXPERIENCED service tech. These solenoids are always going out and are not that hard to change, but they are really complicated to rebuild. Don't be cheap, get a new solenoid.LOL...I am a service tech. and change these valves all the time...Hope this helps....GOD BLESS....Randy...
Nov 07, 2017 | Dishwashers
Dishwashers Logo
159 people viewed this question
Top Dishwashers Experts
