Question about KitchenAid Home
We have the type of sprayer in the sink (or it
We have the type of sprayer in the sink (or actually it sits up out of the sink towards the back of the wall on the ledge of the sink) that you just pull up and squeeze the trigger like device to make it spray out of the nozzle. It should be attached to the sink and only the nozzle should come out when you squeeze, but the base and all has come loose from the top of the sink where it sits. I'm sure there is some type of glue that makes the base adhere to the sink so you don't get hose and all when you pull up on it to spray, do you know what kind of glue that would be? Thank you.
  • 74 Answers
NO GLUE!!!!!!!!!  It is a threaded connection that secures it in place. It is a $5 part at Lowes or HD.
10 minutes to replace.
Posted on Apr 14, 2009
How to disconnect sprayer hose on kitchen faucet?
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
  • Pliers
  • Towel
  • Pipe-joint tape
  • 3/8-inch threaded brass flair cap
  • Basin wrench
  • Sink hole cover
Dec 01, 2017 | Plumbing
Kohler a112.18.1 diverter will not spray
Generally the sprayer trigger assembly will unscrew from the hose. You can then point the hose toward the sink and turn on the
water. It should flow freely through the hose when either the hot or cold is on. Generally there is a aerator on the spray head. You can access it by unscrewing the tip of the sprayer assembly and clean out any mineral deposits. There may also be an inline type filter in the handle where it screws onto the hose that can be removed and cleaned. If this doesn't help I would guess the on-off triggering assembly is broken and you would have to replace the sprayer head.Hope this helps.
Jan 05, 2013 | Kohler Plumbing
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | GE Dishwashers
I pulled the sprayer out and it will not go back into place. How can I get it back into place?
The flex hose for the sprayer can be seen under the sink. It may be hung up on a pipe or other object. As long as there is nothing broken on the sprayer you should be able to ease it back into place by gently applying a "pulling" pressure on the sprayer hose under the sink.
Sep 12, 2010 | Delta Faucet Delta 470-BL-DST Signature...
My hand sprayer on my sink is leaking every time I turn the water on. It's leaking from the sprayer and in dripping under the sink. How can I fix this?
Check for a leaking O-ring/Washer/Seal and replace. Sometimes the internal parts of the sprayer head will wear out. Replacement sprayer heads can be obtained from your local hardware store.
I'll look forward to hearing back from you. :-)
Apr 26, 2010 | Microwave Ovens
Replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
Feb 16, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Bosch dishwasher milluenium series will not drain, drains but water returns to dishwasher the drain pipe goes directly into the grabage disposer can you help?
Here is your problem: http://www.youtube.com/watch?v=S_0OWuFVLNw
Here is your solution: You can go to the hardware store and have them sell you an air gap that sits on top of your sink.  The air gap prevents water from going back into the dishwasher.  The air gap usually goes where the sink sprayer hole is, but if that is occupied by the sprayer, then you gots ta drill you a new hole on top.
If your a cheap bastard, then you can do the poor boy trick called a "high drain loop" where you just fasten the discharge hose at a higher elevation than the garbage disposal port.
Nov 13, 2009 | Office Equipment & Supplies
I have a faucet/sprayer combo and the hose came off when I was using it and now I can't seem to thread it back up....what do I use/do? p.s. I don't know what brand or model...just had to pick something so...
Disconnect hose from sprayer unscrew nut on sprayer head remove washers and you will see a small c shaped clip get that apart then remove hose and thread it back on under sink and feed it back up through sink and reconnect to sprayer
Oct 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Home Logo
76 people viewed this question
Top KitchenAid Home Experts
john h
Tom Chichester
Are you a KitchenAid Home Expert? Answer questions, earn points and help others
