Question about Sony CDX-C5000X
The radio was working, but had to replace cars battery. Now nothing. Fuse is OK.
I replaced my cars battery and now my Sony radio model CDX-C500X won't play. It doesn't do anything. I checked the fuse and it is OK. Do you have any idea what may be wrong?
  • scrtcell May 11, 2010
    I believe there bis a reset button on that radio look behind the detachable face....
  • Brian B May 11, 2010
    did you check all fuses, have you tried pressing the menu button or power button to see if it prompts for a security code.
On the front of the unit there is a reset button. You will need to remove the removable face to access it. Just press the reset button with a pen or something and you're back in business.
check out page 7 of the user manual:
http://www.docs.sony.com/release/CDXC7000X.PDF
Posted on Dec 21, 2009
    Problem Solver:
  • 18 Answers
It's normally just a blown fuse in your main fuse box under the steering wheel area. I'm assuming that when you say you checked "the fuse" you mean the one on the back of the radio unit itself.
Make sure all the wires are connected properly (especially the power and ground wires)
Good Luck!
Posted on Jul 05, 2009
Hi, my problem is that each time I turn off the ignition I lose all my radio settings (i.e. the station pre-sets). My Sony is a CDX-L400X. I was wondering if there is an internal battery (like a button...
Hi, the problem is likely in the wiring or possibly a burned fuse. There is a separate wire to the radio that is always hot and keeps the station and clock settings while the key is off. If you tell me the car model and year, I may be able to tell you which wire and fuse to check. Was this working originally or has it never worked?
Aug 19, 2011 | Sony CDX-L400X CD Player
The entire radio system not working..I disconnected my battery cause needed a new alternator but radio not working now...NOTHING!! No power. I did press the reset button and NOTHING!!! Pls help no radio...
try checking all of your fuses. there should be a fuse box in the engine compartment and another under the dash or in a kick panel. there may also be a fuse in the back of the radio.
Feb 15, 2011 | Sony CDX-GT300 CD Player
Sony CDX GT200 does not work... is there a fuse in this radio? I cannot turn on the unit now. I just got my car back from the repair shop and they replaced my battery and alternator, but now my radio...
There is a fuse in the back of the stereo unit. Also trace the red wire from the stereo to where it's connected, and check the fuse for the circuit that the stereo is connected to.
May 22, 2010 | Sony XPLOD CDX-GT200 CD Player
Sony CDX-s2000 in 2001 KIA Sephia
did you replace the fuse behind the wireharness if so did you check the fuses in the fuse block on your radio. if so you have checked everything try under the hood of your car there should be another fuse box check in there. if all fuses are good check the ground wire on the radio
Sep 08, 2009 | Sony CDX-S2000 CD Player
It doesnt work after battery when dead in car.. i have no remote....i got it with the car and it worked great, now it just open up and nothing....
What has most likely happened is the when the car died it was probably jumped off. Anytime a vehicle is jumped off, especially off a much larger vehicle, a "jump" of voltage is sent throughout the vehicle also known as a surge. The surge travels through the vehicle's electrical system and sometimes blows bulbs, fuses and relays. The back of your radio should have a fuse check it because It's probably blown. If the fuse is good refer to your vehicle manual to locate the fuse panel and find the radio fuse it might be blown. Hope this helps
Aug 03, 2009 | Sony CDX-M630 CD Player
My sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Feb 19, 2009 | Sony CDX-4000X CD Player
Sony cdx-gt200 no power
its knackered either send it in for repair or buy another amp at wholesale cost here:
www.godspeedaudioheaven.com
Dec 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Sony CDX-C5000X Logo
295 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
