Question about Pioneer GM-5100T Car Audio Amplifier
Amp dosnt work right
The amp is pioneer 510t 760watt nothing looks blown when amp is bridged it turns off when hooked up when unbridged works great can u help
  • Perry Babin May 11, 2010
    What is the impedance of the load when you bridge the amp?
  • 47 Answers
Your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Posted on Apr 23, 2009
I have a sony xplod 1000 watt amp, Worked perfect for a month, All of a sudden my subs stop working, But the power light on the amp is always still on. every great while my subs will work again, sometimes...
make sure ur running the right ohm load and if its two channel try bridging it. if already bridged unbridge another thing to check is rca wires i had the same prob with a 1000w explode 2 channel
Oct 12, 2010 | Car Audio & Video
I have a pioneer 760watt model gm5100t amp and two audiobahn 12" subs and I would like to know how the wiring is configured from the amp to the subs as well as how the subs are wired since they are dual...
you bridge the inside + - and use the outside + -
then connect the outside + to the amp then connect the - to the + on the other sub then the - on the other sub to the amp just read this and do it slowly and you will get it then you only have to run the subs on a two channel amp
rate pls
Aug 14, 2010 | Pioneer GM-5300T Car Audio Amplifier
Can i bridge this hifonics amp
If you don't know if the amp is bridgeable, then I wouldnt do it. It could already be bridged internally and bridgeing it through the speaker terminals could be disatrous, i.e. the infamous blue smoke of death. The amp looks like a 2 channel amp fromt he pic and you have two speakers you are trying to power with it. So the safest bet would be to just unbridge your speakers and hook them each up to the amp as normal. No blue smoke. Good luck!
Feb 18, 2010 | MTX Thunder 801D Car Audio Amplifier
I have a rockford fosgate p5002 amp. I have 2 alpine 12" type-r's. I just got them bridged together and my amp keeps going into clipping mode. i tried turning down my gain and adjusting my frequency but it...
Hi unbridge the subs and run them sterio your overloading the amp and its going into protection mode. if you have anymore questions about car audio feel free to ask me...
Feb 05, 2010 | Rockford Fosgate Punch P5002 Car Audio...
I have a 2 channel amp pionner gm 510t 760 watt and i have 2 subs how do i hook them up for the most kick and the hardest pound do i run them series or bridged or whats the best way ????
If you bridge it, it makes 2 channels one channel so you can only have it going to one sub. So you'd have to run them in series and have one sub per channel. If you want lots of bass you need to turn the gain up and adjust the settings on the head deck.
Aug 04, 2009 | Car Audio & Video
I want to hook up my 2 quad coil woofers to a 1ohm amp but
I would look up "series" and "parallel" wiring on the net. Parallel will lower your ohms, which is good- especially for you since your amp is 1ohm. use 1 channel of your amp (unbridged...bridging an amp could increase output, but will Raise the ohms) connect the positive terminal with a wire that goes to the positive on your first sub, and from there, connect a wire from that same positive terminal to the positive terminal on your second sub. do the same thing with the neg. wire. This is called parallel wiring.
Mar 22, 2009 | X-10 Memphis 15-PRC41 Power Reference 4" x...
RCA jacks not working DEH-P470MP
does the amp turn on when the deck is turned on ? is the ground hooked to the body of the car to bare metal w/out paint ect ...under it ? you may want to take it to a installer there are many things it could be they can also test your rca outputs if thats the problem. curcuit city is a cheap place to have your equipment tested if you live close to one
Aug 07, 2008 | Pioneer CD Receiver - DEH-P470MP - CD/MP3...
How to
First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
Oct 31, 2007 | Pioneer TS-W301R Car Subwoofer
Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
Pioneer GM-5100T Car Audio Amplifier Logo
236 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
