Question about Refrigerators
Refrigerator not cooling at all
Hi its a amana side by side refrig takes r-134a..compressor runs back fan runs evap fan does not run (( evap does not get cold))compressor runs an line is pretty warm the other line room temp..i wanna fix myself...evap should be cold?? please help ..thankss
  • 1 more comment
  • niceguy123 Sep 17, 2007
    I CAN WALK INTO WALMART AN BUY FROEN 12.OZ FOR $5.99 CENTS..I AM CERTIFIED TO BUY R-22 R-12 I HAVE ALL THE TOOLS IF ITS MY THERMOSAT WHY IS MY COMPRESSOR RUNNING AN BACK CONDESOR FAN RUNNING AN LINE HIGH SIDE IS WARM TO THE TOUCH LOW SIDE ROOM TEMP .I WOULD LIKE TO TAP INTO IT AN SEE WHAT PRESSURE I HAVE AN WRITE YOU BACK..WHAT I NEED TO KNOW IS WERE AN HOW IS THE BEST WAY TO TAP IN WERE TO GET A FITTING I CAN TAP IN WITH OUR SOIDERING IT IN ..LETS WORK ON TAPPING INTO TO THE LINES AN GO FROM THERE? YA THINK??
  • niceguy123 Sep 18, 2007
    do you guys understand?? i am certifyed in auto a/c i can buy freon .i am not a master refrig tec .i have no idea what pressure it take how much it take's there is no plate telling me how much or what pressure it suppose to be..help me step by step there is no valve to tap in my gage's ..you know they fill them from factory an climp the line off right??(( do you understand ) what im needing help with ??do i make sence?? .just make belive i can buy freon i have gages an tools leak detector vac pump..(( i know the knowlage to proform the work on how how to tap in an what is the pressures are supposed to be..this cant not be that hard to get to check it ..thanksss
    i am certifyed how many time do i have to tell you guys i am certifyed in recover an charging 134a r-12 all refrigebts ..you giys never awswered my questions .wow ..##1 you can tell me to feel the suction line or the discharged line? that is part of diaganoseing a promblem ..correct??i went to school in irving tx also have a dilpolmama..why we ever going with right away freon issues when we dont know an its been a week now nowbody can tell me feel the lines ??or how do you un flood a system since it been on its side ?? i wonder why you guys are not in the feild an sit behind a computer saying you are a master tec frig?...because you can pass a test but cant do the work or awser a question..i had many teachers like that know it on paper but to get out in the real world promblem an do the work they can not do it ..likes like the same here..on fixya.com ..un real
    Sniper:
  • 133 Answers
Noggin is right might have a freon leak or control for your thermostat is broken. Your going to have to get it serviced. It is illegal in most states and ares to do this yourself with FREON.
Posted on Sep 17, 2007
  • 2 more comments
  • Anonymous Sep 18, 2007
    There is a freon plug on the back end of it for installing freon if thats what you think the problem is. If your certified you should be able to find it and know how do do this right?
    Ok, I called my local repair shop and I cant get the exact info your looking for because, he stated and i double checked, Tampering with the FREON in a REFRIGERATOR unless you are CERTIFIED to do so CAN GET YOU ARRESTED. I cannot give you information on this site that can get me or FIXYA.COM in trouble by giving you information to do something ILLEGAL because as you stated you ARE NOT a CERTIFIED REFRIGERATOR MECHANIC, DO I MAKE SENCE, IM SORRY IF THIS CAUSES YOU MORE PROBLEMS. We do not support or give out information that can potentially get us in TROUBLE BY BREAKING LAWS,(Depending in which state you are in and such).
    check this link....
    http://en.allexperts.com/q/Heating-Air-C...
    http://answers.yahoo.com/question/index?...
    is another site for possible solutions.
  • 944 Answers
Sounds like it needs more gas, and checking for leaks. If you have a leak tester, you can test that yourself, but topping it up has to be carried out by an authorised technician, sorry. Call your local fridge guy. Hope this helps :)
Posted on Sep 12, 2007
SOURCE:
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
Amana refrigerator has a ticking sound near the fan
could be the fan motor,compressor or when the compressor is running it could be vibration in the frame,what fan are you talking about,the condenser fan where the compressor is or the evap fan in the freezer?you just have to try and listen and feel the compressor and fan motor when it's running and try to tell were it's coming from,if it's the compressor just use it till it dies,it could run like that for years but i wouldn't take a chance,i would buy a new fridge if it's a fan motor i would fix it.
Sep 15, 2012 | Amana Refrigerators
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
Not cooling enough
sometimes you do everything proper and when repair is done another failure occurs because of long run times because not defrstng . the orginal freon charge may have been alittle on the low side and weakened the compressor what you can do is tap the seal system and add 1/2 of the orginal charge listed below the model # should be 134a this will often work for quite some time and remove the panel off the evap in the frzr and observe the frosting on the coils it should be uniform on the evap with no places getting missed if you can not tell temporily move frzr item and unplug to allow frost to thaw then plug back in and open door allow to run 30 min then look at again if only on part of the evap perhaps top or the lower then you know the orginal charge was low then add freon it sound you are very mech person and possible you may need to add the orginal charge to unit (the compressor has taken heat and it has weakened it)
Aug 20, 2009 | Amana ARS266ZBS Side by Side Refrigerator
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amna cooling problems
first it sounds like a relay...
1 check if you have power to relay. ( use a multimeter)
2 check relay if it rattles its broke..
3 check if compresser is runing..
let me know I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
How to troubleshoot amana refridgerator
the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
