Question about Samsung 206BW Monitor
Monitor had been working fine, but now doesn't. Power is on, everything properly plugged in, yet screen is pitch black. Not able to see anything, not even the menu board.
  • 600 Answers
Is it lcd? shine a flashlight at different angles to see if you see anything ( very dim pic)
Posted on Apr 13, 2009
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Everything turns on but the monitor. The monitor still has a black screen and the light doesn't come on either. I have tried unplugging it and plugging it back in and also restarting the whole thing,...
The monitor has a power supply problem often caused by bad capacitors that in some cases bulge at the top indicating they are open. If you are handy with a soldering iron then you can attempt a repair. The most common capacitor failure is 1000uf depending on the make and model, the value may be higher or lower. To locate the power supply board follow the power cord that is plugged into the monitor.
Jun 25, 2011 | Acer eMachines Black EL1352G-41w Desktop...
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Black screen. Power light is on. Everything is plugged in properly. Rebooted several times. BLACK screen. Not even a flicker of light. HELP!
Have you tried reseating the cables? if not try it first, then if it doesn't work you'll notice that after you unplug the cable that's connecting the lcd from where it's plugged in , (make sure the lcd is on) if you see the colors that means the lcd is working properly if not then there is something wrong with the monitor, but if the colors came up the lcd is working fine,. Try to check where you plug it in.
Feb 12, 2010 | Acer AL1916W 19" LCD Monitor
The monitor was working one day and the next day, it would not come on, screen black. My grandson has had the monitor for almost three years.
I'll hope for the best and assume the simple fix first. Check the plug at the back of the monitor to insure it wasn't pulled out slightly. Sometimes, moving something around can cuse the plug to lose proper connection.
Also, check the power source to insure that you have power to the unit. We had a lightening storm recently and the power strip surge protector did it's job. I turned it back on and everything powered up again.
I hope this helps... Good luck!
Sep 02, 2009 | Computers & Internet
My 195TF is pitch black. Dead or can be fixed?
open the CPU then find the memory and video card then clean both using a paper eraser....good luck....
May 28, 2009 | KDS Avitron 195TF Monitor
Princeton monitor, model # vl1916 Wont power on.
Hi, Billman11, maybe you can repair or maybe not. You need to tell me some stuff first. Need the approx age of the display. Next thing! Does the monitor have external power supply? (black box, sit on floor type) or internal (line cord to wall outlet, and other end to monitor) What exactly happens if monitor is connected to afully booted PC with known good vga output and u connect the flat screen lcd and push the power button? Is lcd panel still pitch black? no flicker or anything? Can you see the power on led indicator even?? From waht you already described it sounds like a Switch-Mode-Power-Supply failure. Each lcd monitor has 2 or 3 printed circuits inside under metal shields beneath the black plastic case covers. In your case, we will want to investigate the board that the line cord plugs into. That will be the smps board, or the little black box on the floor. If you want to try fixing this monitor you can get back to me at louie12fix on fixya or lmistyrel@ aol.com Yes, I'm a vet and spent a year on Kanghwa Do, Korea 67-68 Work for company that provides electronic hardware/software to the gaming industry and located northern Illinois. BYE for now.
Mar 31, 2009 | Princeton Digital VL1916 19" LCD Monitor
Will not power on
look at the vga plug to see if there are any pins bent.
If not then you'll need to replace the monitor.
Mark
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
Black screen with high pitch squeel
Hi...there,
YEah...sure! You need to replaced or repaired your backlight inverter....
Oct 11, 2008 | Gateway FPD2275W LCD Monitor
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung 206BW Monitor Logo
279 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
